[ROM][WIP]CM10.0.0-RC0-BobZ
Is the md5 sum for the 9/15 build in the OP correct? I've 2 separate downloads, both of them have the same checksum, but it doesn't match the one in the OP.
Is there a way to keep the I/O Scheduler as DEADLINE by default when Jellybean is first installed?
My phone kept crashing and restarting itself with the SIO Scheduler, but when I changed to DEADLINE it stopped restarting itself and I can actually overclock it past 600Mhz now.
My phone is also refurbished and it was randomly restarting itself when I overclock it anywhere past 600Mhz but with the DEADLINE I/O scheduler, it doesn't happen anymore.
Would anyone be so kind as to post an md5 checksum from the 9/15 build? I'm getting something different than the OP, and I'd like to rule out a bad download as the cause of an issue I'm having.
I don't have time to write it down and post it but my md5 is different as well
Does the "Set on boot" option not work? It's in the same submenu that you change the setting in.
Anyone have Samba Filesharing working? Mine says enabled but doesn't show an IP address.
BobZ probably needs to sync with the latest CM10 build. Soon, sir... soon.
Is the P500 officially supported by CyanogenMod? If so, then those fixes probably will be in the next build. If not, that thread may indeed have some useful info for him.
It does but its really hard to get to that menu because the phone keeps crashing everytime I tried to go into the performance options. I kept trying and trying until I finally was able to set the I/O scheduler as Deadline and the reboots stopped, but I was hoping if there is a way to keep the I/O Scheduler as Deadline while JellyBean is being installed because it seems stable and overclockable on my phone. I'm sure this would solve a lot of other people's random reboots problem because my phone's symptoms matches very well with quite a few other people on this forum.
I/O scheduler is set by kernel, I'll change it to default to Deadline with next build...people that can OC can change it very easily now.
He just synced with CM three days ago... lol.
And again just now ;)
godef
