[ROM][WIP]CM10.0.0-RC0-BobZ
So I was looking for further info on recoveries and stuff and found this reply in an older thread.
Originally Posted by AndyOpie150
It's not just a matter of installing the recovery, it's how you insall it.
It has to be flashed thru the messed up recovery.
Download a ziped recovery with the "fix recovery loop" option like Zengarden, put it on the root of the sd card.
Once card is in phone, boot into recovery. Go to the "install zip from sd card" option and flash the ziped version of ZenGarden like you would a ROM.
When done go back to recovery menu and choose the advanced options. Select to reboot recovery.
After it boots into the ZenGarden find the "fix recovery loop" option and apply.
Flash new ROM (and Gapps if needed).
So this response was to another person who was also stuck in a boot loop. Can't remember what ROM he was trying to flash, but I just wanted to know if I could use this info and Zen Garden recovery to flash BobZ's Jellybean. If so, I'm sorry I didn't see it before yesterday.
Usually the reason a ROM doesn't boot is the ROM.zip is corrupt, the pre installation wipe was incomplete, or the sd card partition has the wrong format for the ROM being installed.
What recovery are you using? What format is your sd card partition? Please explain everything you wipe and format before installing the ROM and Gapps.
Sent from my LG-VM670 using AC Forums mobile app
I'm using the VM670NH recovery. My SD card partition is FAT 32. When I try to flash, I wipe data/factory reset, cache partition, dalvik cache, then I
format boot, cache, data, system, and SD ext. Then I install the ROM (in this case, BobZ Jellybean from the link on this site), and Gapps, the small, not the latest since they're too big. Running Quattrimus right now. I just want to know if the zipped Zen Garden recovery can be used with the Jellybean ROM or if I have to use the terminal emulator method with the commands.
To use the Jellybean ROMs you will need to reformat the sd card partition to ext.4 (except for the Bean_Whiz-CM10v2.2.2). Most will not even boot unless your partition is ext.4.
You can flash the ZenGarden recovery in it's zipped form just like a ROM (No need to wipe anything). Once flashed you need to go to the advanced section of your current recovery and select the "reboot recovery" option.
Since you have a FAT32 partition you will need to reformat to ext.4 on computer.
Note: You already have the best recovery for our phone installed. It will flash anything. I have had problems with ZenGarden and COT not flashing some things, plus, if you ever need to flash the ZV9 update to revert back to stock they will brick your phone.
I use the Touch Screen ClockworkMod recovery (Just as good as your current recovery, has touch screen in case my physical buttons ever quite working), but it to will brick my phone with ZV9 update. I still keep the Xionia recovery in it's zipped form in case of a recovery loop on my old ZV4 phone (you need COT in zipped form if ZV5 phone), or I need to flash the ZV9 update.
Hope this has cleared up a few things for you.
PS: I really think the SlimRom, or my MOD of it, is the smoothest, fastest, Jellybean ROM with everything working you will find. I even quit using the Mirage ROM (That's saying a lot).
Tried your rom. Can't get past the second CM splash screen (with the spinning circles). Waited a full 30 min. Did a clean install. Any suggestions?
I had the same problem with thekraven slimrom. Seems there is something inherently wrong with either my environment or my process. I can't get anything above Harmonia 2.0 to boot up on my phone.
I'm using CWM v4.0.1.5 recovery. Is that a problem? If I need to update, can you recommend a recovery and direct me to a guide? I've been looking at recovery options but it's not very clear to me how to update recovery. I haven't changed it since I rooted my phone. Is there a lot of shagging around with copying files to the root of the sd, like busybox and superuser, and of course some kind of recovery image file? Changing recovery scares me. I've had good success recovering with this one?
Also, my sd is currently set up to use link2sd. Not sure if that should be causing trouble or not. I would think not.
The partition scheme of the SD card shouldn't matter for the recovery. The easiest way to flash a recovery is from inside Android using something like FlashImg GUI or Anthony CR's Recovery Installer. Before I retired my OV I was using TWRP for the LS670 (same hardware) because I hate not having touchscreen support in recovery.
New and improved!
For Andy's Rom Mod you need to use ClockWorkMod 5.2.0.7 touchsceen.
Read the first post all the way thru, he tells you exactly how to install his Mod, if you follow his instructions to the letter, you should have no problem.
Just for documenting here, I didn't follow clodfelterac's instructions. I basically just followed the devs instructions at XDA in that all I did was flash the script.
so basically my steps were:
1) wipe data, cache, sd-ext, dalvik
2) partition sd-card (2gb sd-ext, 0 swap)
3) mount sdcard
4) adb push bobz rom, gapps, a2sd++ scripts
5) flashed Bobz rom
6) flashed gapps
7) flashed a2sd++
8) reboot
I'm starting to run out of memory. Installed apps can't even update from Google without failing. Been shagging around with moving apps to SD manually to try to free up enough memory just to get an update, even if the app manager shows 70 mb of free ram. Is this the easiest way to fix the memory issue? I was running link2sd on GB and it worked really well. This doesn't look too bad though, if you just flash an a2sd++ zip file. Did you use the slim gapps? Where can I find a2sd++ zip?
Blue Tooth headset won't work with the phone. BT works fairly well otherwise
Update - Unpair / pair sequence fixed problem with phone
What size is SD card?
Wipe:
cache partition
dalvik cache
Format:
boot
data
cache
sd ext
system
Make sure the cache partition is not mounted before the first two wipes and before formatting the cache partition (you can't wipe or format a mounted partition).
Check md5 sum of downloaded ROM and 20110828 Gapps.
MisterVoltio
