[ROM][WIP]CM10.0.0-RC0-BobZ
probably the beats audio.zip flash along with the AudioFX app...that what I use --basically a stock Linux audio improvement. Love it with use of a good pair of buds;)
Obviously don't use with this ROM, however
I wasn't able to mount USB via the recovery in the first post. Anyone else experience this issue? 2nd gen OV.
Pretty bad, I'm waiting for the next release(Because google now scrolling is fixed :D ), Whenever you lock your phone and set it somewhere for like 10 minutes (deep sleep) data turns off (Which is normal) but when you unlock it, data does not want to connect, that's the issue.
You can add "toggle mobile data" to the power widget and keep it off when you are not using it. It's usually there when you turn it on then.
Sent from my GT-P7310 using Android Central Forums
The only data problem I have experienced is when I go from wi-fi to mobile data. For some reason, my 3G won't turn on.
Also, I was in Cincinnati last night (I'm normally in Indiana) and I had full 3G bars, but my data would not work at all. I turned on and off airplane modeand that didn't seem to work. Don't know if that has to do with your ROM, the PRL, or VM, but I thought I would post it here.
That is a current ROM issue sir.
Indeed. That's why I flashed back to Bob's CM9.1. And I went from 9 am to 7 pm with my setup (as far as sync, data, web, text, phone, push notifications, widgets) and got to 35% battery left.
You forgot to mention that I also have a wife and five kids...so that means there are six cell phones in my house :eek:
Thanks to your info, I was able to trim Trebuchet by 10mb...but the ROM is still at 91mb. I've had to make a smaller version of Gapps to be able to flash it completely.
As far as an update: Camcorder is now working and mass storage is working in Linux ONLY. I'll probably release another build this weekend, with hopes of having mass storage for Windows and the data issue fixed...but no promises!
Also bobz, Audio mic needs to be fixed for apps just letting you know :)
Are there any scripts I can flash to have dalvik-cache and apps on to the sd-ext
Apart from that, how bout talking with TheKraven for Audio Routing fix?
Kraven fixed Headphone routing. So now no sound comes out phone when headphones are attached. October 6 is his latest build.
I'm curious about that fix and its compatibility with other 4.0 and 4.1 builds. I would assume that this would require a new build and some more bug fixing at the very least, if it could even be added that way. Regardless, I assume that if someone else did the legwork on this one, barring its incompatibility with 4.1 (and I hope it's compatible), I hope it would be included in future builds.
Might be nice to get an occasional nightly build or something since it seems there's been a number of new fixes but no build for a month
arcworldwide
