[ROM][WIP]CM10.0.0-RC0-BobZ
Still cannot get this to install properly on my s. ROM flashes fine, gapps flashes fine. Boot phone....no setup wizard, no market. Any clues?
Sent from my LG-LS670 using Android Central Forums
Yes. I don't even have an sd-ext. Its like it won't flash fully.
I flashed just the rom, let it boot. Much better. Home key, rom works amazing. Reboot into recovery, flash gapps. No vending.apk. I'm stumped!
I'll test it later when I get time, and I'll report back.
Are you flashing small gapps or normal?
Sent from my One V using Android Central Forums
Where can i get bobz recovery to flash zv9 update and will it put stock recovery back on phone i have to return phone for warrenty issues . The recobery image on th op just downloads a txt document?
Turn that frown into a murderous grin
Small. The one bob posted in the open. Strangest thing. The rom runs great, I just can't find a gapps that works. :(
You have to rename it to a .img and flash it with recovery flasher or a terminal out flash image gui or something. You have to flash the zv9 update twice to get stock rom and stock recovery. You can Google Bob z home's rom website and find a link to his recovery there as well.
come to the dark side
No good I'd. Looks like not clean flash. Resent is showing tico- error??? So sad..
type-R
I think there is something wrong with GApps or the ROM. I just reformatted my SD card, made and sd-ext partition. I STILL cannot get a Play store on clean flash. I know its not a space issue. Has anyone got this WORKING from a clean flash or dirty flash?
I tested to flash 4.1.1. With old bob- gapps and its fine showing google.sign.
type-R
Wow. Weird. I once though on Bob's CM9.1 forgot to flash Gapps and still had Play Store (although I am almost sure it showed up only AFTER I had to manually link my Google account, never checked if I had it before I linked an account)...maybe this may help though?
My worked find I just updated it! Using bobz old gapps modified by me:D
quick question: would installing the non-custom gapps fix voice search, or is that even possible? And about how big of an EXT partition would I need to install it?
Master zx
