[ROM][WIP]CM9.1.0-BobZ
Quick question Bob
I found ur git page from the op, and wanted to ask if ur gonna work on the p3113
I ask this because I have one that despreatly needs hacking.....
So my question is if i can help out with that or a simple kick in the pants toward the right direction.....
Also don't mind helping with the v, just cant catch up to u devs:eek:
VM670 Puff, Puff, Puff,..... just send'n smoke signals
Reactions: StingDrop
Re: [ROM][WIP]CM9.0 RC0-BobZ
The only reason I don't run an ICS rom is they all seem to have the clock lag has there been any info on this issue. But I did like this rom
What apps are excluded in the smaller Custom Gapps?
As far as I can tell, the facial recognition/facial unlock stuff was the main thing left out of the smaller Gapps. Takes up a lot of space.
I'm pretty sure just G calendar and G talk are included. All the rest are downloadable from the store.
I've been running the latest the 6/22 for a few days now, and don't see any clock lag... where would this be most noticeable when I open the lock screen ?
Just wanted to report I've run amphetamines with this build and appears to be more responsive, but nothing concrete. Its worth a try for those interested
Reactions: r00t
I flashed amphetamines this morning while running this rom and have not had any clock lag... and I dont have clock sync installed! :p
What's the best governor setting for this ROM to have the best battery life and performance?
So I go to google play store and chrome browser does not show up. Should it since this is ICS or does the rom do something different? Online it says chrome is not compatable with any of my devices.
Thanks
Thanks
As far as I know its only available for armv7. Optimus is armv6. Hardware issue.
Reactions: nixie21
Works great. What is your opinion of the zram option?
Thanks as always!
Sent from my GT-P5113 using Android Central Forums
Updated OP...we are now at RC1 :-*
I love you :) in like a your an awesome android dev kind of way XD I wanted to sync my godzilla rom's with yours, and hopefully it'll have alot more stability since its RC1 based :DDD
Iknownothin
