[ROM][WIP]CM9.1.0-BobZ
Awesome Rom!!!
Been running since posted and everythings been smooth so far.
Is there any way to turn background data off in ics?
Sent from my VM670 using Android Central Forums
Re: [ROM][WIP]CM9.0 RC0-BobZ
What're the differences from TDM's ROM (and how is it better/worse)?
Reactions: suku92
If you use a certain Touch Recovery, you get a error like
Get prop:error build.prop thunderc
So please, don't get angry at him.
And camcorder is said not to be working. Read before posting. Please don't turn this into TDMs thread with spam. :o
yes you can use romkeeper!
The alpha10 build is in my goo.im folder. But the code is a few Weeks out of date of course. I'd use the beta apk if you want to go that route.
I just tried to flash using touch recovery. I got assert get prop error status 7
If you use cannibal then yes you get error but if you use the other touch recovety (CWMT) then it works.
Sent from my VM670 using Tapatalk 2
was a little hesitant at first. but once it booted up......... definitely worth it 100%
very good job
Reactions: BobZhome
Very good! took the launcher from tdm and placed it in system rebooted and now its working, time lags like 3 seconds, not to sure tho, maybe someone can confirm this :) also please keep this thread clean, this thread is not about which rom is better or worse! Every one has different point of views!:D
Great job Bob! Thanks!
Reactions: BobZhome
I used touch, no prob whatsoever, also installed apex pro launcher from my app backups. This is pretty good the kernel don't like interactive or smartass govs though, they cause a lot of reboots. Runs great for me with interactiveX min 480 max 825
sent from my icy cold optimus using inverted T.T.2
Reactions: BobZhome
Yes, I use InteractiveX with NO root problems!
installed last night. no issues so far. don't use camcorder so that's definitely not an issue for me. thumbs up on cm9 from BobZ
stoffe949
