[Rom][WIP][ZVD] Slimmed CM10 Alpha 6
Status
Not open for further replies.
Re: [Rom][WIP][PORT][ZVD] jelly sandwich CM10 Alpha 5
If it's a "toggle dance" sort of issue, that's not terrible. If it fixes after a reboot, that's sort of a hassle, but also not HORRIBLE.
If it just goes out sometimes with no workaround besides "wait until the magic switch flips to 'on'", yeah, please wait. :)
Reactions: jonny5449
Ya that's what I'm gonna do
Sent from my LG-LS670 using Tapatalk 2
Reactions: Thraeryn
Here is a modified eri.xml for Sprint which will override and replace the Roaming Indicator Off with Sprint. Using a root explorer, copy to the data directory and set the permissions as rw-r--r--., then reboot.
In order to incorporate this into this ROM we will need to replace the eri.xml file which is contained within the framework-res.apk.
https://dl.dropbox.com/u/11009817/eri.xml
Click to view quoted image
Can you re upload I can't dl
Correct but I guess I messed up apps2ext it loads ext apps but doesn't move looking at it
Keep in mind that bobz put a fix to move dalvik cache to a data partition instead of sdext. This was to resolve the optimizing pop up at startup.
Sent from my LG-LS670 using Android Central Forums
Well zakman will mess with it if I know him well lol
Ah man I used the old recovery.....
The old one was based off drew's rom
This is based off bobz rom
Please use xionia or drew's 1.2 recovery or this will not flash.....
Will be fixing very soon
Flash this recovery
http://forums.androidcentral.com/showthread.php?t=179604
Thanks for the quick reply, but the team hydro website is not functional....I will anxiously await the Alpha 6 update
Flash this recovery
You can remove the asserts from the rom them it will flash on any recovery. It's in the following directory.
META-INF\com\google\android\updater-script
Remove the first line. (from assert to the first semicolon.)
Sent from Tapatalk HD
Omg thanks will do as soon as I can I owe you one
Status
Arwen
