[ROM][ZVJ] 2.3.3 DanteRom v4 [UPDATE] 10/14/2012
Re: [ROM][ZVJ] 2.3.3 DanteRom v2.5 [UPDATE] 08/12/2012
Just to double check, the Debug-FormatALL.zip does not wipe the micro sd card, right?
No, it wipes /system, /data, /cache, and /boot. SD card is completely safe
Sent from my Nexus S 4G using Tapatalk 2
Ok I tried to update gmail app and it says it cannot update it requires a newer sdk :-)
Sent from my LS670 using Tapatalk 2
Yes just tried again multiple times dunno what it is. I tried cynogen and worked so I did fresh wipe clean install to make sure
I would try a fresh download and a dirty flash (delete old from your sd card and replace with a fresh download, wipe cache and dalvik cache only, and flash again). Also, since I see you are new and this is an error I have NEVER seen, can you tell me more info on what steps you have taken start to finish? DId you perform a full wipe before flashing? Did you restore apps via Titanium Backup (or similar)?
Edit: Looking back thru I saw you did a dirty flash (did you see in the OP where it said you MUST perform a full wipe?). What rom/version where you on before? Either way, do me a favor and do as I said before and download a new version, boot to recovery, format cache, boot, and system, and flash the rom. I think you some how have 2 Gmail apps
I did that once im sure you are right though ill try it again its not a huge concern for me. I started with stock rooted then installed hydro Rom wanted to try something different so flashed this then installed cannibal over cw I then backed up apps wiped etc went tried cai wound up wipe clear etc. Reflashed this and using root browser installed my apps and here I am today lol. Love the Rom BTW I just like to change all the time and try new things I'm sure I did something to break it lol I seem dsp manager looks interesting so I may try to get it working with some research
Been rocking a dirty flash since last night. No problems, but battery life tanked... Then again I was ocing to 748(?)mhz with all my radios on today :-D
That and using my phone WAY more than on stock... Its not chunky anymore!
Saw the post about the wipe, I literally setup the phone sunday night (on 2.5) and felt like seeing if I got any bugs. As a point of reference, Monday my battery tanked too, due to the OC and use of the phone :-D
Thekraven reports the camera broken on both stock and with his new kernel. Is it broken for everyone else?
My cam works fine on v4 with the kravens fc kernel. Anyone else like to confirm or deny?
Does it matter if the baseband is zvj or can it be mvj? For some unknown reason I updated my wife's phone to mvj instead of zvj way back when.
Pretty sure that's the same
Tapatalk'n it from my VM670 running OM-Mandylion IHO on LS670ZVJ baseband
ZVJ=MVJ
One is the software version and one is the baseband, but we just use the ZVJ to describe both. Feel safe that you are on the right baseband for this rom :D
the fast charge kernel? I've been using it. Even programmed a widget for toggling fast charge on and off.
Yep that's the one. Is your cam working? Mine works but another to confirm would be nice
just took two pictures here just fine, so i dunno what the problem is.
Looks like kravens fc kernel plays nice with the cam on data for everyone but kraven :p
phatjoe824
