[ROM][ZVJ] 2.3.3 DanteRom v4 [UPDATE] 10/14/2012
manage menu form the phone an try (droidsail app2Sd) ,went i move to SD card it reboot , the one u can moved
A2sd is not actually supported. Look for support at the location you found the mod you are using. That said, you don't want to use the native "move to sdcard" option in conjunction with an a2sd mod.
Soooooo... I can't get DanteRom to install. Followed the instructions exactly, can get the wipe zip to work but when I try to flash the rom zip it tells me no file found. ??? It's there, I can select it from the list of zips to flash, but after selecting it is when it tells me the file can't be found.
NEVERMIND!!! Turns out the file didn't download completely :-[ It looks like it's booting up now (pretty multi-colored X splash screen, hoping it doesn't loop that way forever, knowing my luck it would).
And we're in business!
just installed for the first time since v4 and i am having an issue were i cant get apps to download about to reinstall to see is that will fix if not i am going to reflash my old 2.5 zip
Is this from a clean install or are you flashing over existing?
Sent from my Crespo4G using Tapatalk 2
Clean install just got everything reflashed after a new dl and it all works now
Sent from my LS670
Hello
Now I only have one issue, hope you can suggest me fix. The problem I am having is, once incoming or out going call ends and I want to start another call either to same person or anyone, my dialer just stops working, I can't dial someone from my address book or recent calls or from dial pad, It takes about 3 minutes before call gets connected, meanwhile sometimes I get message google.xxx.dialer.com not responding, force close or wait. No matter what I press nothing happens, and in three minutes call gets connected. In simple words, I can start a call once a call in ended for about three to four minutes. Then it works normally.
Can you please suggest fix for these problem.
Hmm . . . That is a strange one. Did you restore any system apps via titanium backup? At the least I would recommend a cache/dalvik cache wipe and dirty flash the ROM again (no other wipes). Hopefully that will do it.
Anyone else had issues with the dialer?
Sent from my Nexus S 4G using Tapatalk 2
Thanks for the info, I did not restored any system apps via titanium back up. I will try to do cache/dalvik cache wipe and dirty flash the ROM again.
Again thx for info....
Uh quick Question. Is it safe to flash a ICS kernel with this rom??
more specifically the kravens ICS kernel from his Oxygen Rom
Is there still a signature verification issue with this package or has it been updated to no longer have this issue?
I just flashed Dante 4.0 fresh - signature verification is built in - no need to mess with turning off signature verification - just do a clean wipe then flash and reboot - simple.
When I do a backup of my phone, do I need to store this backup on my PC?
I'm just not sure where the phone stores the backup. I have concerns that if I "wipe my data", that my backup will also be wiped. Am I making a correct assumption?
Also, what is the difference between a wipe and a format? I have both options in Xionia.
Thanks in advance.
Wipe and formatting data is the same thing also nandroid backups are saved to SD not on phone.
Sent from my LS670
Thanks in advance.
If you have important backups it is always best to store on your pc. But unless you specifically choose the "format sdcard" option in recovery your external storage should remain safe.
And format=wipe :D
I think this might just be Google but after a while I try to install an app and I get error after error then I clear data from play and it works for 2 apps and begins again is there any way to fix it?
Edit: I wasn't having any issues on cm9 cai
Sent from my LS670
Sent from my LS670
I had the same problem coming from cai. Did you do a batch restore with titanium backup, by any chance? That's what I did when I had problems. Did a complete wipe, reflash and installed everything from the market. I haven't had any market problems for the past 24hours or so.
Sent from my LS670 using Tapatalk 2
Sent from my LS670
Is this your issue? Try this mod if so.
http://forums.androidcentral.com/showthread.php?p=1
saujanya
