[ROM][ZVJ] 2.3.3 DanteRom v4 [UPDATE] 10/14/2012
where can i find the base band patch?? my phone says i have ls670mvj_6150 baseband version.my software version is ls670zvj????? also when i restart the phone it keeps booting into recovery and the only way i found to get it back running is to delete davlik cache??
The baseband is read from the ROM not the actual radio you are on. Here is the patch.
http://forums.androidcentral.com/showthread.php?p=2017421
Sent from my Galaxy S4
i copied the patch to the root of the phone and booted to recovery and it says:
cant mount /dev/block/mmcblk0
p1 (or /dev/block/mmcblk0)
(no such file or directory)/sdcard
e:cant mount /sdcard
any suggestions??? im using xionia cwma v1.2518.6 recovery
The baseband patches have extra stuff in them you need to trim out to work with every rom
delete 05mountext and 08reloc in /system/etc/init.d
(old int2ext scripts)
how do I switch from ZVD to ZVJ?
It kinda depends on which ROM you have and which ROM you want to go to. If you have a stock Sprint ZVD and want to go to stock Sprint ZVJ, then you can just use Sprint's normal over-the-air upgrade. You may want to check out my tutorial for other options HERE.
The server where this ROM file is hosted is slow as fat GOO!
I've got ZVJ running perfect, Dante is installed, amphetamine was run. The ROM is AMAZING! Feels like a totally new phone (LG
Opt. S, started stock Gingerbread)
One problem, and I had this before the Amphetamine mod was ran. The clock is now WAY off. It says it's Sunday, 6/30/13 at 3:23 AM, and it's actually 8:23 PM Saturday 6/29/13.
I've looked, and there is no mention of this problem on the thread, and I can't find a way to manually set the time, the only options are 24 hour time, and different display options. What is going on? Is there a fix to it? I'm sadly going to have to use my old phone as an alarm clock till I get this fixed.
I've dual booted my laptop to linux/windows, and I'm the go to guy for tech problems for most people at work, so feel free to talk techy to me.
If I was going to guess... it sounds like it's set to gmt instead of a local time zone?
Usually you can change the time and time zone settings by first disabling automatic settings.
(but admissibly I haven't used DanteRom in awhile...)
Help, I am running DanteRom v4 on my LG optimus s and i have two major problems that need fixing
1 "No Service" just empty bars with a "X" on the top and if i go in to airplane mode, i have trouble getting off of airplane mode.
2 "Youtube can't play videos" i just get this message "Unable to connect to server, Tounch to retry" not just the app also the website gives me the message "sorry, this video cannot be played."
Other than that i give this Rom (5 of 5 stars)
can GoogleQuickSearchBox.apk be replaced with QuickSearchBox.apk?
and if so, where can i find it (or what ROM should i pull it from)?
My phones baseband version says LS670MVJ_6150 (Settings - About phone - Baseband version) and i am running ZVJ DanteRom v4
The about phone report of your baseband is actually hard written into the ROM, not an actual reading of which baseband/radio you are on. What ROM did you last have service on?
Takyi Benedict
