[ROMS for the PEEPS!][CM7/CM9] By Samurai Dev
On s3 the svoice let's me say one phrase, recognizes then force closes,
Any fix?
Also the page you link for gapps is no longer active
Thanks
How did you have almost 800 MB of internal memory on the screenshots ? Sorry if its a dumb question
You need to partition your SD card with a ext 3 or 4
Ohh, doesn't that erase everything on your SD card?
Well yeah, but copy your SD to your PC first and you won't lose anything
Ok so when I backup everything do I partition from Rom manager?
Do not use rom manager for anything!
If you read the instructions on the download page it is written pretty well
NEVER USE ROM MANAGER with the opt Imus V unless you are bored and want to learn advanced trouble shooting! :D
I meant partition the SD card not flash a ROM
Thanks I didn't see that at first, I will try later when I have time!
Ok 1 more question, what is swap and what number should it be ?
So I partitioned my SD card to the 500 mb and my internal memory is still the same, did I do something wrong
is that something that youre likely to do?... ;-)
all one liners aside though,
its quite probable... ;-)
ok, seriously now,
do you know where your towel is?... ;-)
ok, ok, ok... enough with the madlibs... im assuming its because:
a) you partitioned incorrectly
b) the volgons have fried your sd card
ok, seriously now,
Never mind I reflashed and its working I now have space for apps, but one problem is that my phone won't boot unless the SD card is inserted
Trying to get the s3 one to work its a no go
did you re partition your sd as advised in the pm i sent you earlier?... what recovery?... i tested them all before i uploaded... all worked fine (sans the wifi issue w/illusion, which ive fixed)(not uploaded yet)... final overhauls are in the works...
suuu
