[ROMS for the PEEPS!][CM7/CM9] By Samurai Dev
they all work... i just got done re-testing every one of my last updates.... all installed/ran fine (cot2.1rc1), no camera issues whatsoever except better quality imaging... you seem to be the only one currently experiencing these issues which leads me to believe its on your end... bad sd/partition/wipe/flash/flash process/recovery/alteration/etc... i am sorry to hear that youre still having problems... :-(
*** if anyone else is experiencing the above issues with SGS3ICS, please speak up... :-)
I was using the Xperia ROM but now I'm trying the Illusion ROM. I got a Wifi error so I'm going to reinstall. I hope that fixes it.
Fixed the camcorder now, the camera doesn't work it forces close when I try to snap a photo
I tried but it said signature verification error so I toggled it off it installed but it takes forever to boot I waited 30 minutes and it still didn't boot so I restored to cai. Also the link to gapps doesn't work, I'm using cannibal open touch recovery. I tried flashing the Xperia rom and I tried flashing it twice
Hey man use team win recovery and partion your SD card make sure you have a back up on your PC before you do it flash to recovery install and it work. So try it
Hey with the Illusion ROM. I'm getting a Wifi error. Is it due to an error in installation or do I have to run some sort of fix?
Hey i flash the GS3 rom but its not working it just kept loading for hours n never work,
im scared i mess up my phone now, what should i do?
Your phone probably isn't messed up. Did you wipe everything before you flashed (boot, data, system, cache, sd-ext, and dalvik)? If not I reccomend doing that and then flashing the rom and gapps.
Yes i did and did it again many times and it still didn't work , just stays on the bootloader screen :(
no error on your part... its an error on my part... itll all be fixed in next update... switch out the existing build.prop with this one for the meantime... its not from illusion but it should work...
https://www.dropbox.com/s/rdk73aicug6134e/build.prop
Awesome. Thanks man. I keep getting torn between CM9 and CM7. I like CM9 for being able to do the Vol Up + Power for a screenshot and its look. But then I like CM7 cause I can watch HQ videos and some apps actually work.
Try downloading from a Computer, if not then wifi, then do the steps over what kind of recovery do you have or are you using?
I can't get my sd card open up on the computer and RA-thunderc1.1.0-GNM
Can you pop it out and use an sd card adapter/card reader?
Sent from my GT-P7310 using Android Central Forums
uimahe
