Root for Galaxy S5 on Marshmallow
No need to reset but flashing a new ROM you will definitely lose root, there's no need to check. Trouble is whether the update phone can be rooted as downgrading is generally out of the question
Hey guys please I really need help. I followed every step shown in the guide and in the video here [SM-G900*] CF-Auto-Root | Samsung Galaxy S 5 then I download this file SM-G900T (T-Mobile US): CF-Auto-Root-kltetmo-kltetmo-smg900t.zip then I open up odin and see the COM blue then I did like in the video. Then the box said RESET and my device reset and got stuck in the recovery booting recovery is not seandroid enforcing window. Am I ****ed? There is no red android . What am I doing wrong? I did exactly and read word for word. Please help...
Hello and welcome to Android central joshsamsung182
Reflash the CF-Auto_root kernel for the G900T model, again and if it boot loops, wipe the phone's cache partition as per # 1.3 of S5 Update Problems - Dummies Guide to see if that solves your issue.
i have a g900f 6.0.1 do i need unlock oem?
The international model, G900F, does not need to be carrier unlocked to root it. The international model, unlike some of the U.S. variants, also does not have a locked bootloader, either.
okay thanks , only one more question i have the build G900FXXU1CPC9 and i only find the build G900FXXU1CPD3 its there a problem if i root with it?
Sorry these is the correct
AP : G900FXXS1CPI6
cp : G900FXXU1CPC9
csc : G900FTPH1CPE2
So your actual build, not baseband, is PI6. In that case, you will need to use the PH3 CF-Auto-Root, here. This is for PH3 and higher, builds.
i did the root but now it not boot shows a msg
" Recovery Booting...
Recovery is not seandroid enforcing
Set Warranty Bit : recovery "
what i do? help please :(
Got it!!
i tryed again in download mode ( only thing that boot )with build G900FZHU1CPH3 but same error .
tryed the other build G900FXXU1CPD3 and worked .
It seems that what matters is the ZH and XX in builds,(seems that has to do with the global version) :o
hope this helps someone with same problem!!!!
thanks for the answers :D
That was indeed, my bad! At 02.00 hrs in the morning, I am not at my best. I clicked on the wrong CF-Auto-Root link, for ZHU, (Hong Kong), instead of the one above for XXU, (Global). Glad you are up and running. :)
I am newbie and want to root my cellphone.
Android Version: 6.0.1
Model Number: SM-G900MD
Baseband Version: G900MDUBU1CPE1
Build Number: MMB29M.G900MDUBS1CPJ2
Do i still use the Auto-root from the linked thread or do i need to find a specific?
Hello and welcome to Android Central Junior Sanches!
Just follow the instructions in the links of post #1 to root your Brazillian dual sim model, G900MD. The CF-Auto-Root kernel is...
CF-Auto-Root-klte-klteduosub-smg900md.zip
I already ****ed up so i need help getting out of the Samsung logo with the "recovering booting".
Any way to try again?
Trying to do a Recovery boot does not work either.
tinni99
