Root Motorola Photon 4G without the HD Dock.
Can any body tell me why or what went wrong when i tried this process above? Here is a copy of my cmd line. Any help would be much appreciated.
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Installer01>cd
C:\Users\Installer01>cd ..
C:\Users>cd root
The system cannot find the path specified.
C:\Users>cd root
C:\Users>cd ..
C:\>cd root
C:\root>adb push photon torpedo.tar /data/tmp
'adb' is not recognized as an internal or external command,
operable program or batch file.
Android Debug Bridge version 1.0.26
-d - directs command to the only connected USB devic
e
returns an error if more than one USB device is
present.
-e - directs command to the only running emulator.
returns an error if more than one emulator is r
unning.
-s <serial number> - directs command to the USB device or emulator w
ith
the given serial number. Overrides ANDROID_SERI
AL
environment variable.
-p <product name or path> - simple product name like 'sooner', or
a relative/absolute path to a product
out directory like 'out/target/product/sooner'.
If -p is not specified, the ANDROID_PRODUCT_OUT
environment variable is used, which must
be an absolute path.
devices - list all connected devices
connect <host>:<port> - connect to a device via TCP/IP
disconnect <host>:<port> - disconnect from a TCP/IP device
device commands:
adb push <local> <remote> - copy file/dir to device
adb pull <remote> [<local>] - copy file/dir from device
adb sync [ <directory> ] - copy host->device only if changed
(see 'adb help all')
adb shell - run remote shell interactively
adb shell <command> - run remote shell command
adb emu <command> - run emulator console command
adb logcat [ <filter-spec> ] - View device log
adb forward <local> <remote> - forward socket connections
forward specs are one of:
tcp:<port>
localabstract:<unix domain socket name>
localreserved:<unix domain socket name>
localfilesystem:<unix domain socket name>
dev:<character device name>
jdwp:<process pid> (remote only)
adb jdwp - list PIDs of processes hosting a JDWP transport
adb install [-l] [-r] [-s] <file> - push this package file to the device and i
nstall it
('-l' means forward-lock the app)
('-r' means reinstall the app, keeping its data
('-s' means install on SD card instead of inter
nal storage)
adb uninstall [-k] <package> - remove this app package from the device
('-k' means keep the data and cache directories
adb bugreport - return all information from the device
that should be included in a bug report.
adb help - show this help message
adb version - show version num
DATAOPTS:
(no option) - don't touch the data partition
-w - wipe the data partition
-d - flash the data partition
scripting:
adb wait-for-device - block until device is online
adb start-server - ensure that there is a server running
adb kill-server - kill the server if it is running
adb get-state - prints: offline | bootloader | device
adb get-serialno - prints: <serial-number>
adb status-window - continuously print device status for a specifie
d device
adb remount - remounts the /system partition on the device re
ad-write
adb reboot [bootloader|recovery] - reboots the device, optionally into the boo
tloader or recovery program
adb reboot-bootloader - reboots the device into the bootloader
adb root - restarts the adbd daemon with root permissions
adb usb - restarts the adbd daemon listening on USB
adb tcpip <port> - restarts the adbd daemon listening on TCP on th
e specified port
networking:
adb ppp <tty> [parameters] - Run PPP over USB.
Note: you should not automatically start a PPP connection.
<tty> refers to the tty for PPP stream. Eg. dev:/dev/omap_csmi_tty1
[parameters] - Eg. defaultroute debug dump local notty usepeerdns
adb sync notes: adb sync [ <directory> ]
<localdir> can be interpreted in several ways:
- If <directory> is not specified, both /system and /data partitions will be u
pdated.
- If it is "system" or "data", only the corresponding partition
is updated.
C:\root>adb shell
* daemon not running. starting it now *
* daemon started successfully *
$ cd /data/tmp
cd /data/tmp
$ /bin/tar xf /data/tmp/photon-torpedo.tar
/bin/tar: /data/tmp/photon-torpedo.tar: Cannot open: No such file or directory
/bin/tar: Error is not recoverable: exiting now
$ /data/tmp/photon-torpedo.sh
/data/tmp/photon-torpedo.sh: not found
$ /data/tmp/install-su.sh
/data/tmp/install-su.sh: not found
$ cd /data/tmp
cd /data/tmp
$ cd /data/tmp
I've been debating if I should root my photon for free tethering or (mobile hotspot) but is that a good reason to root? And also does this method of rooting without a dock legit or is there other methods? Any advice helps. Thanks.
SENT FROM MY MOPHO BLASTER
I'm having problems with getting my Photon rooted. I tried both the manual process via ADB and also the one-click method.
In both cases, the problem seems to be that there are two devices running, my Photon (TAxxxxxxBJC) and an emulator (emulator-5554). With the ADB method it appears that I should be able to stop the emulator device via the ADB command, but then the next time I use ADB (for example, to get a list of devices) a Daemon kicks in and restarts the emulator.
I'm pretty sure if I can disable the emulator and keep it disabled (I notice that one of the first things the one-click method script does when it starts is to fire up the Daemon and restart the emulator) that I could complete the process and be rooted.
Can anyone help me with how to defeat the emulator and keep it from loading during the rooting process?
Many thanks.
Just to follow up my previous post, here's the command line playback of the one-click script:
Getting temp root
error: more than one device and emulator
RE-boot-en
Hackin Things
deleting all yo
Copying files onto phone...
Setting permissions...
Installing busybox...
Cleaning up files...
"You should have root!"
Press any key to continue . . .
Dweil,
Did you put your phone into charge only mode before you started the one click root?
I was able to recreate your problem doing the root with out charge only mode enabled.
Once I changed to charge only mode it rooted like a champ.
[YT]http://www.youtube.com/watch?v=SaJ0uiExdFM[/YT]
I followed this videos instructions..
Reactions: roomaire
Herk,
I'm pretty sure I was in charge only mode, as that is normally my default. I'm on the road, but I'll check again when I get back home next week.
Thanks for the suggestion.
Herk,
Let me know how it goes I rooted with the phone in USB mass storage mode and got the exact same error you are experiencing.
I have tried everything and i cannot get root. It says that i have it with "one click" but, root check denies
Great help guys! Either the process is getting easier or I'm getting better at this because I got it on the first try and it took me 1/10 of the time to root this as it did my Optimus
I agree my optimus was definitely a tougher nut to crack this was easy!!
So I have rooted my MoPho in an attempt to get some tethering going (which I am still working through). But other than tethering, help me understand what I can do now that I'm rooted?
I was able to root the phone successfully and install and enable the Wifi apk. I can connect to the device with my laptop (im on it currently) but unable to access the hotspot with my tablet. Is there a setting I am over looking on the phone? If I should ask this question else where, please direct me. I am using an ASUS TF300 Tablet.
Thanks all.
FloatOn
TheGreatApe00
