[Root] Samsung Epic 4G Official Froyo EB13 w/Optional EXT4
I am a complete noob and you seem to know what to do. I have the epic and EB13 factory 2.2.1 and I am having issues with the camera and sport mode. I want to install Genocide as you suggested, but i have no idea how to do it. I have ROMManager, but it wont flash the epic recovery. It will to all the other choices, such as the captivate, facinate, etc.
So, my questions are as follows :
1. How to flash the proper recovery with ROM Manager or use one of the choices instead?
2. how to install genocide 0.3a?
Thank you for all your help
1.) Stay away from ROM Manager. It was cause you more headaches than its worth.
2.) If your looking just to do the camera fix and not flash custom ROMs and themes, etc.. Then goto the first post in this section and use Procedure #1. This will give you root access and install CWM v2.5.1.0. Once that is done you can download and flash the Genocide kernel from CWM.
3.) If your looking into trying custom ROMs and change themes, do all that fun stuff then I would suggest moving to Procedure #2 and install the CWM3.0.0.6/EXT4 Filesystem conversion.
4.) If you have any more questions, please come back and post in the appropriate thread based on your question.
Good luck :)
I cant down load this file EB13-DUALFS-KERNEL.zip all the down load links are dead can some one please fix this i am dead in the water till this is done...
i have a "superuser" app now. i would assume that means i am successfully rooted
Download Titanium Backup from the Market, It should ask you for Root User permissions when you start the app up and you would answer by saying yes. This would confirm that you have successfully "rooted" your phone.
Reactions: robomav
Major thanks to Paul627g and Ragnarokx; you made this easy for a noob... Any word on a bluetooth voice dialer fix?
Odin direct to prerooted EB13 with CWM 3.0.0.6 and ext4
Ragnarox, can I accomplish the same thing by following instructions at this page:[Stock Flash][Odin]EB13 Extended CW2.5+RFS or CW3+ext4 2/24/2011 inc. Root+Redir. - xda-developers
Quote from page
"Stock EB13 Deodexed EXT4 + CW 3.0.0.6
Instructions:
Step 1. Boot your phone into download by powering off your phone holding 1 on the keyboard and holding power til you see the little Yellow digger.
Step 2. On your computer launch the included odin.exe and select the included EB13-ext4.pit and under PDA select the included EB13-Extended-3.tar
Step 3. Plug in the usb cable.(if it's done right you should see a yellow Com device.)
Step 4. Tick Repartition
Step 4. Click Start and wait.
That's it. You've got EB13 Release and clockwork preinstalled, rooted, and ready to use.To get into Clockwork, hold Volume Down Camera and Power to flash your own rom."
Quote from page
Instructions:
Yes the Odin method above will give you everything in one package, one shot all done. Rooted/CWM3.0.0.6 deodexed ready to roll.
Reactions: mredamon
Help :(
When I install the Samsung driver it seems to install correctly but when Windows tries to configure the drivers it fails and my computer doesn't seem to recognize my phone. And when I run the "run" executable in the one-click-root, it says Phone Not Plugged In. Is anyone else having this issue? Is this the part that I have to try multiple times?? Thanks
If you are still having problems, you can try uninstalling the Samsung drivers you downloaded from the link in Step 0, and download and install this driver (select "Software" at the bottom; it should say "Device(Install),USB Driver (Software) (ver.1.0)") instead.
You can try that driver I listed above or try again with the original driver. Usually after you install the driver you have to plug your phone in and Windows will go threw another series of installation to fully complete the driver installation. For me on 2 of my computers it has taken a good 10 minutes for Windows to completely install the drivers before it was ready.
Sorry if this question has already been asked.... I'm finally about to jump over from TER to EB13. Was going to try a few ROM starting with Syndicate. On the Syndicate page, it says to simply run CWM after using odin to go to EB13. Would that be the same thing as jumping straight to part 2 of this thread? Or do I need to run part 1 first?
using the preloaded method could not have been any easier. only took me a few minutes to get my phone up and running.
Thanks, ran this last night and other than the computer not seeing the phone issues it was perfect. Followed this up with the ACE Rom and the wife is much happier.
my father in law got an epic last night; it didn't have EB13. Within 20 minutes i had it running Eb13 and rooted! Thanks for all the support and great contributions! Love the AC forums!
chzahid600
