Rooting for Eclair and leaked Froyo DK28
no i'll try that now. but like i said i have no problem mounting the phone when debug is off
no i wasn't.... i wasn't getting the option to even if i wanted to do it. looks like it might be working now... i'm up to "setting permissions..."
spoke too soon... looks like i'm stuck there
phone froze again..
Wait for phone to reconnect...
Mount system as r/w, cleanup old files, do some basic configuration
* daemon not running. starting it now *
* daemon started successfully *
90 KB/s (4813 bytes in 0.052s)
Copying files onto phone...
1282 KB/s (26264 bytes in 0.020s)
1612 KB/s (196521 bytes in 0.119s)
391 KB/s (14428 bytes in 0.036s)
1299 KB/s (486948 bytes in 0.366s)
33 KB/s (479 bytes in 0.014s)
Setting permissions...
if it stays stuck for another 2 or 3 min, try (without doing anything else) turning the phone off and then on again, and see if the process starts back up. Setting permissions is the rooting part, so it may have worked even if it froze. You can install busybox and superuser on your own.
had to do a battery pull.. phone was completely frozen. restarted and i have superuser now but titanium is saying i don't have root =\
jesus christ yet another error message
Exploit made by joeykrim and one click installer made by noobnl and firon
busybox by skeeterslint
Press any key to continue . . .
Phone is not connected.
Copy and run the exploit (may take up to two minutes). Ignore messages about re-
logging in.
If more than five minutes pass, reboot the phone and try again.
Starting adb server...
* server not running *
277 KB/s (5392 bytes in 0.019s)
[*] CVE-2010-EASY Android local root exploit (C) 2010 by 743C
[*] checking NPROC limit ...
[+] RLIMIT_NPROC={3712, 3712}
[*] Searching for adb ...
[+] Found adb as PID 2198
[*] Spawning children. Dont type anything and wait for reset!
[*] If you like what we are doing you can send us PayPal money to
[*] 7-4-3-C@web.de so we can compensate time, effort and HW costs.
[*] If you are a company and feel like you profit from our work,
[*] we also accept donations > 1000 USD!
[*] adb connection will be reset. restart adb server on desktop and re-login.
mount: Operation not permitted
failed to copy 'rootsetup' to '/system/xbin/rootsetup': Permission denied
Unable to chmod /system/xbin/rootsetup: No such file or directory
/system/xbin/rootsetup: not found
rm failed for /system/xbin/rootsetup, No such file or directory
1221 KB/s (26264 bytes in 0.021s)
1776 KB/s (196521 bytes in 0.108s)
939 KB/s (14428 bytes in 0.015s)
2253 KB/s (486948 bytes in 0.211s)
116 KB/s (479 bytes in 0.004s)
Unable to chmod /system/bin/playlogo: Operation not permitted
Unable to chmod /system/xbin/busybox: Operation not permitted
Unable to chmod /system/xbin/remount: Operation not permitted
Unable to chmod /system/xbin/su: Operation not permitted
link failed Permission denied
Installing busybox...
/system/xbin/busybox: permission denied
Press any key to reboot the phone
exactly the same thing. this is making loading custom blackberry roms look easy
holy crap i think i got it... dont' know how though
But the good thing about rooting is you only have to do it once - until Froyo comes along that is =/
That's the nature of the rooting beast - there's no real logic to it, it just happens lol.
What to do next: crack open a cold one and celebrate lol.
But seriously - next stop is ClockworkMod Recovery. Before you make any other root-related modifications to your phone, you need to install Clockwork and make a backup of your system in case you mess anything up (there's a how-to thread around here somewhere). But that is a story for another day. I'm calling it a night. Glad you finally got it working! :D
Reactions: murso74
thanks again dude.. gonna do that clockwork jammy and go to bed myself
When you got stuck at "restart adb" you said you closed the command prompt. I take it u figured out to restart adb in the task manager?
Rag another thing I think I read in this forum peoples phones were unrecognizable and mounting/adb.
I'm pretty sure you can't install the drivers with debugging on. And the only time I turn debugging off is at school when plugging it into a new computer so it can find the drivers
Sent from my SPH-D700 using Tapatalk
So you're saying the first time you plug your phone in after installing the drivers it should have debugging mode off?
Sent by a little green robot
i dont really remember anymore. i just know that some computers will not recognize the phone to install the drivers or get the computer to recognize the phone, the first time you need to have debugging off.
so i guess just install the drivers, plug in your phone with debugging off, make sure it says its recognized. then unplug your phone and turn debugging on and continue.
because when i use computers at school to copy my drafting files to my sd card, the computer wont recognize my phone with debugging on
no i was restarting it in the task manager the whole time. i only closed the command prompt when it hung up. the for some reason i always had 2 instances of adb running when i closed it out though. then after i closed one it automatically restarted as a single occurance. the time that it actually worked i had to end the process like 4 times for it to continue
Hmm there is something is suggest which i think is very important.
If they just want to root they should do that, but if they want to use a new rom and kernel this should use http://forum.androidcentral.com/epic-4g-roms-hacks/34603-clockworkmod-recovery-instructions.html
Because it roots ur phone and it gets clockworkmod. In essence you will do 2 things at once. Also put something on how they can check if they are rooted. For example, go to command prompt and run adb shell, type su, and if you get # that means ur rooted
yanis
