Rooting for Eclair and leaked Froyo DK28
Actually my phone does need to apply the update.zip, but it does so automatically. I haven't see the stock recovery screen in a long time.
when you boot into clockwork from your phone off by holding the volume down and the camera key as you power up, it takes you straight to clockwork?
for me when i power up from a cold start like that it takes me to normal recovery and then requires me to hit update.zip manually, which takes me to clockwork.
but if i boot into recovery with my phone on - aka use rom manager and hit "boot into recovery" itll take me straight to clockwork as it should
Yup, doesn't matter how I do it I always go straight to Clockwork. I'm not even sure if it's possible for me to get into stock recovery anymore lol.
I either used an ancient method or I somehow messed up.
too bad I don't remember which method I used.
Sent from my SPH-D700 using Tapatalk
i used the method in the sticky for clockwork and i am having the same issue as shaun
I did it! I figured out it was a problem with the Samsung driver. I tried installing everything on my girlfriend's computer and it worked like a charm. I now have Baked Snack on my machine! I still can't get it to work on my computer, but since my girlfriend lives with me, I'll just use hers.
Thanks to everyone for their help!
First of I am a COMPLETE noob to Android
I have spent HOURS reading and following instructions on this thread and I cannot get past the whole failed everything phase:
Exploit made by joeykrim and one click installer made by noobnl and firon
busybox by skeeterslint
Press any key to continue . . .
Copy and run the exploit (may take up to two minutes). Ignore messages about re-
logging in.
If more than five minutes pass, reboot the phone and try again.
Starting adb server...
* daemon not running. starting it now *
* daemon started successfully *
337 KB/s (0 bytes in 5392.000s)
[*] CVE-2010-EASY Android local root exploit (C) 2010 by 743C
[*] checking NPROC limit ...
[+] RLIMIT_NPROC={3424, 3424}
[*] Searching for adb ...
[+] Found adb as PID 63
[*] Spawning children. Dont type anything and wait for reset!
[*] If you like what we are doing you can send us PayPal money to
[*] 7-4-3-C@web.de so we can compensate time, effort and HW costs.
[*] If you are a company and feel like you profit from our work,
[*] we also accept donations > 1000 USD!
[*] adb connection will be reset. restart adb server on desktop and re-login.
Wait for phone to reconnect...
Mount system as r/w, cleanup old files, do some basic configuration
mount: Operation not permitted
failed to copy 'rootsetup' to '/system/xbin/rootsetup': Read-only file system
Unable to chmod /system/xbin/rootsetup: No such file or directory
/system/xbin/rootsetup: not found
rm failed for /system/xbin/rootsetup, Read-only file system
Copying files onto phone...
failed to copy 'su' to '/system/xbin/su': Read-only file system
failed to copy 'Superuser.apk' to '/system/app/Superuser.apk': Read-only file sy
stem
failed to copy 'playlogo' to '/system/bin/playlogo': Read-only file system
failed to copy 'busybox' to '/system/xbin/busybox': Read-only file system
failed to copy 'remount' to '/system/xbin/remount': Read-only file system
Setting permissions...
Unable to chmod /system/bin/playlogo: No such file or directory
Unable to chmod /system/xbin/busybox: No such file or directory
Unable to chmod /system/xbin/remount: No such file or directory
Unable to chmod /system/xbin/su: No such file or directory
link failed Read-only file system
Installing busybox...
/system/xbin/busybox: not found
Press any key to reboot the phone
I don't know if I have the right clockworks installed and I don't know how to delete the one I did install... but someone mentioned clockwork wasn't necesary to root
This is EXTREMELY frustating :mad:
arcy.... try this. once you plug the phone into the computer pull down the notification bar and make sure that your SD card isn't mounted as a drive. if it is mounted then the program won't be able to mount it to copy the files.
if it says
Turn Off USB storage
Select to turn off USB storage
then you have to press that so it says
USB connected
Select to copy files to/from your computer
i know it seems backwards but it works
ragnarokx - yes, all three ports
if it says
Turn Off USB storage I don't have this on my screen as an option
USB connected
Select to copy files to/from your computer I don't have this on my screen as an option
OK so I have absolutely no clue how to mount or unmount the the SD card. So far I went into the notification area and I had three options for USB:
1- Charge only
2- Sync
3- Disk drive
I have it under charge only and tried running "run" and I get the same failure as my initial post.
EDIT - BTW all files in initial step have only been downloaded to laptop and not to phone (don't know if that makes a difference).
you do have debug mode on right? just double checking...
try to do it as a disk drive and then go into the notification bar and unmount it
Yes debugging is on
I have no clue about the mounting part (sorry I come from a smartphone os :confused: )
I did this as well:
settings > connect to pc > charge only
settings > wireless & networks > wifi unchecked
settings > sound & display > screen timeout > never
And formatted the SD card
It shouldn't even ask you whether or not you want charging only tether mode or usb drive if you have debugging
1- Charge only
2- Sync
3- Disk drive
This is all done on the computer. You should not move any of these files to your computer.
And since I don't think I have debugging on go:
Press "home"> "menu"> settings> applications> development> debugging. -make sure it is checked
When you plug in your phone you should see a red triangle with an exclamation mark inside.
If you pull the notification bar it should say "usb debugging connected"
Guys prior to replying PLEASe read all posts!
I do greatly appreciate your help BUT you are being very repetitive! Although I am a complete newb I do know how to follow instructions, I have read ALL 14 pages worth of info.
I have debug ON
I have changed usb ports
I have downloaded files to my phone
I have (i think) phone unmounted
Are you using the one-click root method? If so, I would recommend setting back to factory and trying the method I posted above. While a little more involved, you won't experience so many problems.
Here Ya Go
Did you also try a different USB cable?
Yes debugging is on
I did this as well:
How did you get to the "settings > connect to pc > charge only" option? I don't see "connect to pc" under settings.
thats why i told him to turn debugging mode on.
he says he has it on. but that option only pops up with debugging mode off.
so i did read all the posts all the posts relevant
Here Ya Go
one-click root will have to be my next option =/ Phone is actually with factory settings. I just received it two days ago so I really haven't done anything with it.
nop, I used the one that came with the phone and I don't have another one
If you scroll down the list in settings there is an option to connect to PC. When you go into that option the only option available is Default connection type and if you tap on it it will highlight charge only or sync. The charge only is in smaller print within the same Default connection type.
I hope that makes sense
I've never seen that settings option before. Can you upload a screen shot? ShootMe is available in the Market and it's free.
yanis
