rooting problem!!!
skywalker98
11
hi started the root (auto root) and it got down to where it rebooted and we lost connection ..now when i try to start root over from #2 and type y it goes back to type 1 for start from beginning or 2 to resume .I have tried both numbers and typed y and enter and it does the same thing over ...HELP PLEASE!
Can you please clarify more where you are in the root process, ie. where exactly this occured, which autoroot are you using? Im looking into this now, and will respond when I figure it out.
edit 1:// Were the updates complete when you "lost connection"? And what exactly lost connection? The phone to comp via USB?
edit2:// If the autoroot is not working properly in going to the second step, and it wont restart, you might need to start again using a manual root method using ADB.
liquidsnake757
