S Note - missing tools / Mode?
Hi all
I have note 10.1 2014, and I dont get the productivity tools on snote at all. I tried changing the default template to blank, but the tool icon didnot appear. I tried what Chris brennan1 suggested, and the box appeared, but i would rather have that appear in the tool box. Any suggestions?
thanks
A screen shot of the missing icon would helpful. Is this the icon you're missing? If you have it just click on it to get the other productivity options.
Sent from my SAMSUNG-SGH-I317 using Android Central Forums
Folks are still missing the question. There are some templates in S Note that DO NOT OFFER THE PRODUCTIVITY TOOLS ICON.
For example, the Memo template does NOT have the productivity tools icon. However, the other templates all seem to have the icon.
My question is why do some templates have the icon and some don't?
In my SNote, none of the templates have that icon. But I found out that the snote app for note 10.1 2014 does not have that icon, instead we have to use the lasso tool, and then the tool comes up with properties, transform into, cut and copy choices.
thanks
i am also missing this productivity function. I feel like this is a downgraded versions. Also, the icon Snote is very different from the previous version. What is going on? Can someone help us?
where can i find the selection tab? also, how can i access the productivity tool? I'm desperate for help. Would really appreciate you're advice bro.
I noticed in the S Pen Tutorial and on the GN2 commercials that S Pen should have Productivity Tools, Shape Match Tool, Formula Match Tool, Handwriting to Text Tool however when I open S Pen (whether manually or by physically removing the S Pen) I do not have those Tools at all. I only see Drawing Mode, Text Mode, Eraser Mode.
what am I missing
Hi all, I am using note 4 and I had the same problems too but now I found it.
In the newer version of S Note, all you have to do is draw something first, then you use the tool called "Selection" (dotted cloud icon) to circle (or just tap on) that thing you have just draw (e.g. shapes, formula, texts, etc). Then you will get more option to transform it into shapes, formula, or texts.
Hope this helps!
You're a life saver! Your found is so helpful, I love my tablet, and its so good to know that it doesn't miss anything.
noroldie
