S View flip cover for the Edge?
With out the cover it works perfectly normal. It's the flip case that's the issue
That's pretty sucky. They should put an option in so you can choose to have that panel behave like it has no case. Is there a place to send suggestions to Samsung about improvements and ideas? I have a couple of minor annoyances too.
I found case on Amazon, similar to the S View, but not sure if it's legit.. Anyone used it? (link: http://www.amazon.com/Samsung-Galax...ag=hawk-future-20&ascsubtag=UUacUvbUpU4174893)
I do not think it's legit. It does not have the chip in it that enables the s view cover to work. I would not trust it. The official samsung flip case requires you replace your battery cover with the case. As you can see in the photo.....the chip connector on the official samsung flip case.
--- Sent from my fantastic Note Edge--- "IT'S NOTE A GIMMICK, THEY JUST HATE US CAUSE THEY AIN'T US!!!!!!"✒✒
That's what I figured :/
They make after market s view and edge wallet combined on eBay but the window and edge features don't work.. Eye have a Samsung official wallet and a after market and the official case is only 40bucks and can use it while the case is closed.. Looks extra slim and sleek
I too have the flip case... pretty cool except I wish it was a true black and not a shade of grey...
I just got my edge today. How do you make calls from the lock screen with the quick call? I tried Nd it won't let me
I have to ask that question too in a way but mine is about the flip cover not staying closed as somebody pointed out and i wanted to know if that was true.
The contact has be added to the emergency dialer. Tap the + sign to add it, then you'll be able to call from the lock screen
I like mine and have had it for 6 weeks. However, the cover stopped functioning in that the phone no longer sleeps when cover closed nor awakens when cover opened.
Try pulling the phone apart from the case and then reconnecting it. Maybe the connections aren't making good contact. I read before where this fixed the problem for someone.
The cover is more rigid at first, but it gets better pretty quickly. Putting a card helps it a lot, weighs down the color.
Thinking about getting this phone, though I told myself I'd never use anything with touchwiz... ;)
Does this case make the volume rockers hard to use? Or did they think of that too? Thanks guys!
I got the case yesterday, works great, maybe a touch harder with volume rockers but nothing to worry about, they work with with case closed. I wouldn't of thought of it till i read your question and checked. The magnetic closure is nice and gives you the date time on the edge panel when you close it. Definitely worth it. I use Nova launcher but am having trouble with it crashing every now and again. Its a great phone i had a note 4 for a week got it cheap second hand but like the Edge better.
I loved the Edge flip case and would not ask anything more since you already have the edge where the S view options should also appear.
insidious1
