S-View Flip Cover issue?!?!?
I have had no bluetooth issues with my phone or the cover. It connects immediately when I get in the car, even if the cover is closed and in my pocket. I would un-pair the phone and re-pair it to the car to see if it helps. (Making sure the profile is also deleted from the car's bluetooth before re-pairing.)
I have had issues with my bluetooth and the s-view cover as well. It is the spigen s-view cover. When I click the button to send a command to my phone from my SMH10 for my motorcycle, it doesn't register. When I have it flipped open its fine.
Just wondering if anyone else is having the same issue as me with this cover. Whenever I have the phone sitting down the flap will not lay down completely on the screen. It's about 1/4 of an inch off the screen which is very annoying(especially for $60.00) I've been working the flap back and forth with no results. If it doesn't completely close. I'm going to return it before my 14 days is up and order a Otterbox.. If anyone else is having his problem please let me know... Thanks....
I was having this problem at first! Then, I know this may sound stupid, I realized that I did not have the back of the case firmly snapped into place on the flip side. It has happened to me several times. Try pressing the case firmly to your device between your fingers all along the edge. I hope this helps! Also! Ive had mine for a while and it always stays firmly to my device.
Same issue here but what do you expect there's no magnet to keep it down or anything. . I just lay my phone face down on the screen
cripes! I'm glad I saw the make sure it's snapped all the way post....feel kinda dumb but it lays perfectly flat now.
Hello, already sorry for my bad english but, i will explain an sulotion for the issue..
I had the same problem till now.
I putted a marker between de back and front because it will make some extra room so it will close perfectly.
A tip is that you put some water on it so its easiër to stratch a little and now my cover is closing perfectly.
EifelBytes
