S voice network error
Yes.......I too have the same problem now. It was working just fine up till a couple of day's ago. Hmmmm, Samsung probaly put the "Nix" on it. Oh well...went back to Stcok one and it works just fine. Too bad.......really liked the New S Voice. I am sure it will be in the Note 3! :):)
hi guys im new here after minutes of finding some answers why my s3 is giving me network error i think its because i installed explorers or root apps.. because i have read 1 post that explorers do have conflicts with s voice.. what i did was i cleared the data in s voice and forced to stop it.. i disabled it and uninstalled fx explorer and ES explorer.. restarted my phone and enabled Mobile Data.. enabled s voice again and now its working fine..
hope this helps.. if it helped you pls like my page in facebook.http://www.facebook.com/computerReviews?ref=hl thank you
Out of the box s-voice keeps giving me the no network connection error whenever I am connected to a wifi network and only works with 3g. Today I tried telling s-voice to turn on wifi while only connecting to 3g then turn off 3g to see if s-voice still works. Somehow it solved the problem and s-voice now works fine with just wifi :cool:
I think keeping wifi on during sleep will fix this problem. I am trying it now --( Settings::Wifi::Advanced).
I suspect that S-Voice does not have a retry and fails if WiFi is sleeping. Mine fails the first time -- but works if I repeat the command -- which tells me that the first command causes Wifi to wake up but the command fails because S-Voice does not wait for Wifi to wake up before sending the command.
They could cache the command until Wifi wakes up. Or put a retry into the code so S-Voice tries twice -- the first time wakes up wifi. Or they could put a setting in the OS to select "Always use 4G for S-Voice" (which would work better on busy WLANS).
motoJunkie1
