S Voice not working
The standard procedure for "Unfortunately......has stopped is to clear the cache partition which the OP said he has done!
You can't Force Stop S Voice on my Note 3, in fact you can't do anything because all the selections are grayed out, even clear data!
Madd54,
I've run out of ideas on this one! It's a pisser!
hi Jalopiejoe!!!!!
thanks for your interest !!!
nop...., still the same thing here.....
tried with wipe cache, rebooting, nothing works.......
I was thinking if Google talk could interfere with S voice....
G talk works ok, mic works ok......, so It's an app issue... it happens after running on Lollipop :-X:-X:-X:-X:-X:-X:-X:-X:-X
Whenever I see a post that says..."Unfortunately _ _ has stopped" I look to see the cure!
I have not found anything that will help you yet!
Hello,
I flashed phoenix rom on my S4 to change it in S5
After flashing about after 2 to 3 hours S voice stopped working and showed same error.
I don't know that installation or update of any app led to this issue.
I also Uninstalled S voice and installed another Svoice.apk that I downloaded from Internet that also didn't worked.
One thing more ,I recently changed (ic audio codec) because mic was not working perfectly.
If anyone found a cure for it please post it on this thread.
I think I am near the problem !
I Uninstalled S voice from S4 and in my s3 mini I turned s voice into .apk file (with the help of apk extractor ) and installed that .apk file in my S4 .S voice worked in s4 but it didn't installed properly ,because when I double tap home button s voice do not opens but when I open s voice from app it opens.
A3 running Lollipop...........
Screen msg; "unfortunately s voice has stopped"......s voice screen is blank!!!!
How to fix; Settings>App Mgr>S Voice>Permissions>Toggle all permissions on.
S VOICE WORKING, YIPPEE!
timo82
