S10 plus or Note 10
Ohhhhhh
Believe me, it's got a heck of a lot of stuff.
And it runs so Dang smooth.
My wife has a note 9.
She is about 5' tall.
It she got used to the weight .
And she totally loves the 4000 ah battery.
My camera..I dont have any complaints.
And I came from a Pixel 3 XL
Want me to say more.
Go for it!
You get more for your money with an S10+.
Basically, as others have said, unless you really need an S pen, save yourself a few hundred bucks.
For the small differences that you are talking about.
Bigger screen.
More ram.
S pen
Look at it.
For me.
I will pay the difference
It's like tools in a tool box.
The more tools you have.
The better your options are
Watch "Samsung Galaxy Note 10 Plus vs S10 Plus" on YouTube
https://youtu.be/MSn4M7eA8lc
Bigger screen.
More ram.
S pen
Look at it.
For me.
The op asked about the S10+or Note 10.
Neither note has now memory.
They have the same size screen, but the note 10s is lower quality.
The note has the S-Pen, but both lose the headphone jack, which some find a more valuable tool.
The note 10 also losses the micro SD slot.
Tools are great, but if you just stuff everything you find into your box, you're just weighing yourself down and wasting money.
If you care about storage then the S10+ has a 1TB option, which is something that the Note10+ surprisingly doesn't have.
256 gb internal storage with a Sd card is not enough storage.
Headphone Jack's.
Have you seen how many bluetooth headphones are out there.
How do you do a workout with a cord hooked to you.
The screen on the plus is great
The camera is very good.
I cut 10 1/2 lots on a zero turn.
Leave my phone in the garage.
Don't want it on me.
Bigger screen.
More ram.
S pen
Look at it.
For me.
Wrong phone. For the record, OP says Note 10 not Note 10+.
Even so, a Note 10+ is throwing even more good money after bad, IMO, if you don't really need an S Pen.
S10+ has 128 gb Internal storage.
Note 10 + has 256 internal storage.
You dont need for your car to do over 75.
So limit it so it has a governor.
Because you will never need the extra speed.
Headphone Jack's.
I actually use Bluetooth, but I'm also capable of understanding that a lot of people still want a headphone jack.
Once again, we're talking about the note 10, not the note 10+. I honestly don't know why you can't grasp this concept...
Who, needs a 1 TB storage ?
Really.
Even just as a option
Its a 512 SD card
https://www.digitaltrends.com/mobile/samsung-galaxy-note-10-plus-vs-galaxy-s10-plus/
SD cards fail from time to time and no SD card is as fast as on board storage. At least there is an option. And I bring it up because I have a 1 TB Ceramic Black S10+. I just listed it as an option. I don't know what the OP prefers.
FYI, they make 1 TB SD cards as well so there is a market for it.
Yes, I also went with the S10+ 1Tb storage and 12Gb of ram and ceramic black like you. I no longer worry about space for apps, music, video, pictures etc and I've noticed no lag at all period.
My work phone is a Note9 and it's a great phone also. I do use the Spen on the Note to capture customers signatures and that's probably the only time I ever use it. I'm sure there are others that use it constantly and it is nice that you can use it to snap pictures and such.
Yes, the SD card. That was also a must for me, even with my 1Tb of storage. Just pulled it out of my old phone, popped it in and all my saved documents, pics, music were right back on my S10+. I also wanted the headphone jack. I have a really nice pair of over the ears headphones that sound amazing! But they're 1/4" so I have to use an adapter to go into the headphone jack. I haven't found a pair of Bluetooth buds that can even come close to the sounds I get from those headphones. So, if you really want and need the Spen, get the Note10. If you want crazy storage, ram, SD card slot and headphone jack, go for the S10+ ceramic edition. It really depends on what you "need" with the phone. Hope this helps you a bit! I'd say you really can't go wrong with either models.
In leaning towards the S10 plus, so my last question. What's the mobile signal like on the 10+? Were there issues with some phones?
I don't have any signal issues on my S10+, but I didn't have any signal issues on my previous phone, an LG V20, on Verizon either.
The only other Android I can compare it to that I've used daily is my BlackBerry PRIV. That phone was lucky to get 1 to 2 bars of 4G. The S10 + always has 3, sometimes 4 bars of 4G. Definitely a better antenna than my Priv, and better signal in other areas where 4G was weaker on the Priv.
Honestly, if the Note10+ had a 1Tb model, I probably would have went with it. I personally just wanted all that storage, even though it didn't have a headphone jack or SD slot. Too bad that they didn't do the same for the Note model. Even though I really need the Spen, I would have went that route.
And for antenna questions, I live on the eastern end of Long Island, NY. Lots of bad no signal areas out in certain areas. But still, I've always had good battery life. I'm really impressed with this phone.
Edit, the signal strength I mentioned above is at my house, not in general. Heck, in most good areas my 4G is at max.
ruhidubey017
