Sjp66 Member May 26, 2022 11 0 0 May 26, 2022 #1 I recently did a factory reset on my S20 ultra and i used to be able to swipe up on my homescreen to reveal a second row at my dock but it wont do that now .
mustang7757 Super Moderator Moderator Feb 6, 2017 96,898 12,730 113 May 26, 2022 #2 Welcome to AC! You using a 3rd party launcher?
mustang7757 Super Moderator Moderator Feb 6, 2017 96,898 12,730 113 May 26, 2022 #4 So when you swipe up u get to app drawer?
Sjp66 Member May 26, 2022 11 0 0 May 26, 2022 #6 The first row of the app drawer is always visible but it wont let me add another row
mustang7757 Super Moderator Moderator Feb 6, 2017 96,898 12,730 113 May 26, 2022 #7 Can you post a screenshot https://forums.androidcentral.com/showthread.php?t=413366
mustang7757 Super Moderator Moderator Feb 6, 2017 96,898 12,730 113 May 26, 2022 #9 Ok the 3 lines at bottom left bring up recent apps is that what your looking for? Do you want use gesture instead of button?
Sjp66 Member May 26, 2022 11 0 0 May 27, 2022 #10 i know about the 3 lines but that doesn't change the dock. No i don't want to use gesture instead.
mustang7757 Super Moderator Moderator Feb 6, 2017 96,898 12,730 113 May 27, 2022 #11 How do you want to change the dock? You would need a 3rd party launcher
Sjp66 Member May 26, 2022 11 0 0 May 27, 2022 #12 It's not recent apps but favourite apps in the dock.
mustang7757 Super Moderator Moderator Feb 6, 2017 96,898 12,730 113 May 27, 2022 #13 You can change those 5 apps in the dock u currently have but if u want more customize then 3rd party launcher
Sjp66 Member May 26, 2022 11 0 0 May 27, 2022 #14 My phone came like that from new and it's something that i liked and got used too.
mustang7757 Super Moderator Moderator Feb 6, 2017 96,898 12,730 113 May 27, 2022 #15 Yeah , if you want more customization then look at 3rd party launcher or if you want keep stock launcher the Good Lock app in play store.
Sjp66 Member May 26, 2022 11 0 0 May 27, 2022 #16 So i can't simply change it in settings? What launcher would you recomend? Where would i download it?
mustang7757 Super Moderator Moderator Feb 6, 2017 96,898 12,730 113 May 27, 2022 #17 No there very little u can change in settings, Nova is one of my favorites
mustang7757 Super Moderator Moderator Feb 6, 2017 96,898 12,730 113 May 27, 2022 #19 Sjp66 said: Where would i download that? Click to expand... Play store
