S21 Ultra Accessories especially case with slot for stylus
sunkissed64
8
Hi I'm waiting for my S21 Ultra to arrive and trying to get a little ahead of the game by getting the usual "stuff" that comes with getting a new phone. My last phone was an S7 Edge. Can I still use the same chargers (wall charger, car charger etc? I have the adapter to be able to plug the S21 in. Should I go with newer chargers? Do they perform that much better to warrant a purchase?
I'm also looking for advice on a good option for a screen protector that offers good protection but doesn't make me have to push buttons really hard or block fingerprint identification.
The case is a big consideration for me. I will be buying an S Pen stylus so I'd love it to have a slot to hold the stylus, manufacturer's names would be helpful.
Thanks in advance for your help/advice.
Sunny ☀️😎
PS
Any advice on a good site(s) for buying accessories at a decent price would also be great.
Ah easy one, nice.
Your chargers will work fine. A Samsung 25 watt one will be faster, but only you can decide if it's worth it. I charge overnight and it lasts all day.
Screen protectors, Whitestone or AmFilm tempered glass are probably the best.
You have a choice of 3 cases, the 2 from Samsung and a Spigen one... The liquid air P I think.
I am using the AmFilm screen protector. My first install the fingerpribt sensor was awful but someone suggested putting the weight on faster so tried the 2ns one and so far it's working well.
I have the Spigen sPen case which is well made and have read its better than the Samsung. The thing I hate is that it's on the left side due to the volume controls on the right. I'm right handed So it's awkward to have to reach to the left side and reposition my left hand to get it. It will make it not as convenient for me to bother using as much. If it pulled straight up it would be better. Someone does have a case with it on the back. I'm waiting on reviews to see if it effects wireless charging a lot.
Bought both of these cases that can hold the S-Pen...
Bought the Samsung one because I wanted the S-pen that I couldn't buy separately at the time... I like the texture of the Spigen one better. Samsung one is silicone and things gets stuck on it.
The S7 edge comes with a micro usb tip and the S21 will be usb c, so your car charger will not fit. I am not sure if the cable that comes with the S21 is USBC to usbc or usb a to usb c. Perhaps someone here can let us know. If it is USB c to c then you will need a charger. The 25W samsung would be the best bet at this point.
The cable that comes with the S21 is C to C, but the OP said they have an adapter already.
I hope someone makes a more rugged case with the S-Pen slot. Neither of the current available cases I would consider rugged.
vann
