S25 rolling it's first update
has the april software update for at and t model came up yet i'm still waiting for it to be pushed out over wifi not sure if it supposed to been friday or not i did install playstore update on friday after manually check it
Still nothing for me on at&t unlocked.
Reactions: mlblack16
They have been delayed for some reason about 2 weeks
so basically you saying 1st week of may prob get april update or 2nd week why delay anyways?
It's been out for 2 weeks now not sure what the delay is on Att.
At this point can be anytime when they do.
Anyone have location icon showing continuously since the update?
I'm not getting any excessive battery usage warnings for any apps, but not sure what is constantly using location services.
Reactions: kevinpleasants
Yes. With the latest update the location icon is always visible. The system uses location all the time and the icon reflects it.
Yeah, I did some more investigation and discovered the same.
I'm using Good Lock to now hide the visibility of the icon
i heard about this since at and t not delaying anymore i assumed sometime tonight or tomorrow it be pushed over wifi then i'll install
alot of folks are complaining about percentage battery icon over at samsung forms saying too small or something like that is it that terrible?
i didn't know if you just click on download and install it will start doing it wifi should left it alone wait for it to do it
anyways odd thing my notifications were white i had to restart phone then everything was back to normal because using galaxy theme from last month in it it did asked about date and time but it was everything was correct i restarted again message went away i then email myself gmail notification wasn't white
still trying to figure out how to stop location to appear as far as battery icon goes i see no issues
I got so annoyed with it sitting there flashing on and off that I did the exact same thing. No more icon.
You can hide the location icon by downloading the Quick Star module for Good Lock.
when do you guys think samsung is going to fixed location icon sometime this month or next month perhaps?
wanamartah
