s3 gt-i9305 help help wiped everything
Dave Winfield
5
so i rooted succesfully
then went to install a custom rom and thats where it went wronf
followed instructions and it failed
but it told be to format wipe and clear everything
so now phone turns on and just sits on the samsung galaxy screen
its a uk phone on 3 network
can anyone help please
regards
dave:mad:
It's pretty unusual for custom ROM instructions to tell you to wipe EVERYTHING - do you know/remember if you wiped the /efs partition?
At least it gets that far. Have you tried booting into Download (Odin) mode? If that works, you can either try loading the stock un-rooted firmware using Kies or Odin, or you can try loading your custom ROM using Odin.
Edit: welcome to the forums.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
cant remeber if i wiped efs
i can get the phone into either download and recovery mode but thats as far as it gets.
everything has been wiped so lets look at it that way lol.
i did find a link on a different site on how my problem can be solved but his links lead to mediafile and they have been shut down so i cant get all the files to do it.
no matter what rom i throw at it through mem card it just wont install any of them
this is my wifes phones and she is really busting my balls hahahaha
All sorted fixed it and wife is happy once again
using Sony ultra c6833
kiki2025
