S3 without 3G pls help!
Sergio Olvera
Hi there, well im new in this forum and i hope any kind of help...
well first i live in Mexico and recently i bought a
Verizon S3 i535 Android 4.1.2, band base VRBMF1, rooted, Apn telcel
i use an unlocked microsim for TELCEL Mexico but i cant connect to 3G network, is working with 850/1200, someone told me changing the baseband possibly works.
but first i need to know if this will works or i will need to buy another phone, any idea how to fix it?, if needs more info about the phone pls tell me.
Thank you guys for the help.
Welcome to the forums.
I am not sure you can force the Verizon phone to work. There are 2 types of 3G bands. GSM and CDMA. CDMA can't work on GSM. If your carrier is a CDMA type, now the frequency comes into question.
You can try contacting your carrier and asking if they can support a Verizon phone. If they say no, then I would get a different one.
chzahid600
