S6 Edge Plus APN straight talk settings help! Anyone?
alex lewis2
13
S6 edge plus APN straight talk settings help!
hi guys, i recently got a new s6 edge plus. it is unlocked from Verizon and im using it with an ATT straight talk sim but i can get picture messaging sending or receiving to work at all. i changed the APN but i got data to work, it works great its just the picture messaging part.also i cant get it to check voicemail as soon as voicemail picks up it says this call cant be completed and if i call my own number to check it the phone acts like it doesnt hear my putting in my password. any help?:(
Re: S6 edge plus APN straight talk settings help!
It keeps saying my phone isn't compatible with straight talk which makes no sense because I'm using it right now and I have data and texts and calls just can't figure out the mms
Can you ask them to re-send the settings
But can you see if your APN settings are correct? If you're unable to edit the current APN, can you create a new APN with those settings?
