S6 Edge Vibration, can I get some help?
peashhhh
S6 Edge Vibration
Hello,
I have bought S6 Edge 3 months ago and I am facing a problem for last few days.
It's about vibration. When someone calls me, my phone doesn't vibrate like before i.e two long beeeeeeeeeeeeeeep and instead, it gives two small vibration 'bep-bep' and then complete silence. What could be the problem? Because of this I can't answer to most of the calls as I usually put my phone in vibration mode. Please help.
Thanks in advance.
Re: S6 Edge Vibration
Hello,
Thanks in advance.
Did u tried changing vibration in setting>sounds and vibrations
Or check do not disturb setting?
×× SM-G925F ××
AndLesUK
