S7: battery drain caused by android system and operative system android. Can I please get some help?
  • Start date Start date
A
AC Question
S7: battery drain caused by "android system" and "operative system android"
Hello,
I have a samsung s7 since a week. I noted that my use battery is affected by a battery drain caused by:
"Android system" (about 24%)
and
"operative system Android" (about 12%)
Screen is on 20-25% (but it is normal)
I read something on google to solve this problem (knox process uses 7% and Gear VR service uses 7%) but I don't understand if this problem can be solved.
Please, can you help me? I spent a lot of money for it. :-(
Thank you!
Re: S7: battery drain caused by "android system" and "operative system android"
Welcome to the forums. Do you use the device a lot? If no, then the system showing the most use can be normal.
ridi
