S7 battery problem?
Does it need to last 2 days? Are you away from a charger for that long? Because I can't see any other reason to go that long. Otherwise why would you push it that far in power saver unless you just don't use it in which case, why have a smartphone as powerful as the S7? Any time I've used power saver the phone is slow and sluggish.
No. It does not need to last 2 days. It was lasting 12 hours until I turned on power saver.
No. I charge it every night.
Yes, I use my phone extensively.
Why an S7? Because my S3 puked out on me.
What the he77 do you care anyway. You use your phone however you like. It's none of your business what I do with mine.
I suggested turning on power saver. What do you care?
Go play with your tinker toys in the sandbox.
I care, because it doesn't fix the root of the problem.
Sandboxes are fun.
Jayarealways
