S7 edge Battery life
I wiped the cache many times and still cannot get the battery life you are getting. When it goes to 60% I just about be at 2hrs SOT or less. How do you get that battery life?
I also did a factory reset too. If gear vr is at the top of android system you should try to clear its chache and restart. My android system drain either fixed itself or clearn gear vr's chache did it for me. I was having terrible drain until recently. Im not sure if the factory reset did it or if i got some update.
Sepembers update initially caused drain. This doesnt even compare to the usage i use to get. But its much better.
You know, I'm thinking of maybe picking this phone up in a few months (okay, maybe nine months - if my phone holds up!) ; so knowing that the battery life is this good is awesome!
It is really good. If i didnt touch it so much i could easily get 2 days out of it.
How is this an accurate gauge of your batt life, you can clearly see you charged it again on the 10/2!
In two and a half days, one charge from about 50% to 90% isn't bad. It depends on SOT. If OP let it sit, then it's not very good. But if he used it alot, id call it pretty good.
Can someone help me with my battery life, right now I'm only getting about 3 hours sot. I have gone through and disabled stuff but still horrible battery life.
gulkhile
