S7 Edge - I can't find anything wrong
anon(9408097)
759
10 points to anyone who can point out something wrong with this phone.
Except touchwiz :p
Re: I can't find anything wrong
32 bit audio? Don't think so.
I didn't see the Led notification. Is there?
Storage for pictures and different files like music or pdfs is not good at all?
32 bit audio.
Does that affect bluetooth or sonos streaming, or just wired headphones?
No front facing speakers?? Should also be a 64gb option. Personally don't give a monkeys about SD cards.
It seems a very common complaint with Galaxy phones is they become significantly slower as time goes on. I wonder if that is fixed.
64GB option confirmed for select regions:
Except touchwiz :p
If I can get a version of the Edge that's not tied to AT&T's Byzantine release schedule even for security updates, I may consider it.
I'm excited. This will be my first Samsung phone since starting with Android on the original Droid. I really tried very hard to not become a Galaxy sheep (No offense) but there really is too much goodness going on here to not try it. Especially the cam improvements, even though the G4 has served me well in that regard, will be very nice for snapping shots of the little one. Done with LG after all the hardware issues though. Hopefully better luck with Sammy.
With the 4GB of RAM and that battery, seems like a winner to me
AOD consumes less than 5% over a 10 hour period.
So none of you have won the 10 points yet.
32 bit audio? Maybe. And no front facing speakers? That's lacking, yes but the audio coming from the mono speaker isn't "wrong" or bad by any means.
I'll give the speakers issue 3 points that's it. I have the S6 edge and I've never felt the need for front facing speakers to be honest even though I've owned the one m8 in the past.
This is really surprising :o
And there has to be a notification led! There will be don't worry about that. If there isn't I'll give everybody 10 points here because I think that's an important feature despite of having the always on display.
Still can't easily swap the battery. Lithium batterys degrade after about 200 charge cycles. Iphones can have it replaced at a store even though it's expensive and they have to turn their data over to a stranger.
Isn't Samsung's only solution that you mail it in. Will a do it yourself option be possible?
Lack of timely Android updates (especially when you factor in the carriers), but that's going to be the case with any non-Nexus phone.
robe3123
