S7 edge Reception issue
limitbreak09
464
Anyone here has problem with the reception? Im only getting 1-2 bars most of the time in my home but on my 5x I gets like 2-4 bars.
Are you having any problems? If it is just the bars then I wouldn't worry about it
I was waiting for this feedback. Yep, it looks like the S7 has the same crappy antenna like the S6.
dreaming of electric sheep
Hmm so far no issues. Calling and texting is good, and 4g lte has no issues too. Its just my ocd is killin me lol. But I will see in the next few days if i will encounter any problem.
My phone while at work is much better than my previous LG G3... 2 bars of LTE coverage when I was barely getting 4G on AT&T... Very happy with the reception.
What is the actual dBm? Bars are useless for the most part since all phones calculate bars differently. The actual dBm signal will tell the true signal at all times.
I use signal check pro (top left of my screenshot) so I can always see the actual signal.
Not saying the S7 has better or worse reception as I do not personally have one, but should not be the same with the Snapdragon 820.
Additionally, the Samsung Galaxy S7 and S7 edge integrate Qualcomm® TruSignal™ multi-antenna boost technology to intelligently compensate for signal impediments, improving call reliability, data speeds and call coverage while reducing radio power consumption
https://www.qualcomm.com/news/relea...ssor-powers-next-generation-samsung-galaxy-s7
Right now 2 bars with -100-106 dbm. I also got a new sim so idk if it has something to do with it.
Well, I am getting better reception in certain areas than I did with my old note 4. In my car for example.
Posted via the Android Central App via a kicking Gold Galaxy S7 Edge.
Check the dBm now on your Nexus 5X and see if it is the same. I wouldn't be surprised if you're near 100-106 dBm on that but the 5x shows 2-4 bars versus 1-2.
My S7E is actually have better signal. *AT&T
AT&T: 4 bars LTE signal strength -87 dBm 53 asu
Signal is as good as my S6 edge and my Nexus 6P
Ok i will. If my 5x has better dbm should I replace my current device? or maybe try to get a new simcard first?
( my unit is silver but I woudnt mind changing to black tho.??????)
Ok so Im compared the dbm between my 5x and s7e and its the same. Around 102-105 in my casa. Just weird that 5x is showing more bars than the Edge
Ok so Im compared the dbm between my 5x and s7e and its the same. Aeou d 102-105 in my casa. Just weird that 5x is showing more bars than the Edge
Yep :). That is why you always want to check the -dBm signal. Each manufacturer (sometimes even the carrier gets involved) will display different bars even though the signal is the same. It does kind of suck .. It would be better if there was a "standard" for how many bars = the true signal strength.
Ikr, they really should set a standard for it. Lol my OCD was killin me and ready to get my device replaced but thank u for your advice it calms me down now lol.
Just compared my s6 edge+ with my s7 edge (SD820) and the signal strength is identical. ~110dBm in my house which isn't too great. That said, this is leading me to be a bit skeptical of the "TruSignal" in the SD820 variants.
kelkongko0510
