S7 Edge screen protector messes up after putting on case
pst23
78
First things first the fact that I can not a decent screen protector is taking the enjoyment out of this phone. Also I had the zagg hd dry and clear and they both got messed up once I put different cases on the phone.
Re: Must we choose between a case or a screen protector?
It might be an issue with certain cases and/or screen protectors. Hopefully it's not a problem for all.
I didn't have a problem with my case or screen protector
I see its unavailable now in the reviews they talked about bad cut outs. Mine a lines perfectly
It's an issue with your case and/or screen protector overlapping the screen's edges. 95% of cases are manufactured to be flawless with the phone, and with a screen protector you add .1/.2 whatever to your screen, which interrupts the seamless design. I have a case on my s7 edge and also have a zagg shield on it. Have had it for 2 days now with that setup and it is perfectly fine.
Skinomi had issues with their screen protector, so they sent me a free replacement. But it works fine, just needs the time to dry completely, and set up.
I have the Zang HD dry on my s7 edge. Most cases did mess it up, but after trying on like 6 in best buy it finally found one that didn't mess it up. It's the clear speck case.
I just got the zagg hdx and the spigen tough armor. When I put the case on, the corners of the zagg started lifting. Never had this happen before.
I'm getting a new zagg for other issues (debris on sticky side when it came out of the box), but don't want out to happen with next one when it arrives
I'm using the Zagg HD with both a Spigen Neo-Hybrid Crystal TPU case and an Otterbox Commuter. No corners coming up or anything else after a month.
amezD
