S8 LTE problem
  • Start date Start date
A
Android Central Question
Guys need some help . I am using Samsung S8 every time I receive or make a call my 4g or LTE turn s off automatically after that call and I have to restart my phone in order to use LTE again... any suggestions to fix this..
Welcome to Android Central! Which carrier are you on? Is VoLTE turned on?
Check your network setting under mobile network. Make sure your network mode is set correctly. Verizon usually is set to global. Network name should have your carrier listed. Go into Access point names and make sure you have one selected.. I have in the past had problem when moving from one cell tower to the next. I have verizon and have changed my network mode to LTE/GSM/UMTS. This has helped me when in low signal areas. Keep in mind these are preconfigured settings from your carrier. Can and will revert back to original settings. Also check advanced calling features to allow HD voice and video
kurniaa
