Samsung Android 15 Beta Registration /Beta Builds
Remember this is Beta so most likely it will get fixed as the clock weather widget the temp and time are very small as well, so I'm sure it will get fixed , just like i have clock alarm set up and the clock icon is missing on the status bar.
Clock for alarm is hidden under notification status bar, i think that's great idea that way home status bar is much cleaner
Reactions: jamezr
Yes i have np either just saying looking more like iPhone design lol , but at least you can go back the old way on the quick panel with notification.
when you download the OS, did it automatically set the dual drop downs? (quick panel/notifications)
Seems Samsung internal testing has smoother animation compared to the public beta
Reactions: jamezr and MS3GT
Andriod Auto giving problems on Beta
Reactions: Laura Knotek
Bit the bullet and installed the beta. CGMs are NOT affected and work as expected.
The smaller font and widgets seemed to have left extra "real estate" at the top of my home screens/screens. I see others say this will likely be fixed with the release or next beta. I don't dive deep into the UI, but so far, it seems Release ready. The app drawer, I like. And again, as long as you don't use the Private Folder, there is no affect on the CGM Software: Libre 3 and Dexcom G7.
Heyan
