- Feb 6, 2017
- 98,928
- 15,586
- 113
There's an app in the Galaxy store for us on One UI 7 called display assistant which allows more customization.
Yup seen it on YouTube, i tried it , but i don't need it, but probably good for those that can use it.There's an app in the Galaxy store for us on One UI 7 called display assistant which allows more customization.![]()
Yeah it has some pretty cool tweaksYup seen it on YouTube, i tried it , but i don't need it, but probably good for those that can use it.
I'm waiting on Home Up and lockstar, Quickstar as well those 3 and I'll be golden lolYeah it has some pretty cool tweaks
Yeah those are supposedly going to be soonI'm waiting on Home Up and lockstar, Quickstar as well those 3 and I'll be golden lol![]()
I downloaded it and saw the options, and then I uninstalled it because i probably have no use for it.There's an app in the Galaxy store for us on One UI 7 called display assistant which allows more customization.![]()
Yeah some will like it others not but it's available only on One UI 7 at the moment.I downloaded it and saw the options, and then I uninstalled it because i probably have no use for it.
Thanks for the tip! I'm going to check it out.There's an app in the Galaxy store for us on One UI 7 called display assistant which allows more customization.![]()
just get it done, Samsung. I'm already braced for a long-delayed and mostly cosmetic update.Looks like only Samsung device getting Beta is the s24 and all other models will go straight to One UI 7 in February release date.
I want the animation to be like the pixel and its getting closerjust get it done, Samsung. I'm already braced for a long-delayed and mostly cosmetic update.
Got it, thank you.January Beta 3 is rolling live.
Downloading now...January Beta 3 is rolling live.
That's greatFinally was able to get into the beta.
