Samsung Android 15 Beta Registration /Beta Builds
My battery isn't super great but it doesn't seem too bad. The overall experience is really smooth though. This version seems to run well and seems much snappier than the prior.
Reactions: Laura Knotek
there’s a visual overhaul throughout it's entire system homescreen, widgets, and more. The notification tray and Quick Settings are also split, though that’s optional and there are new lock screen tweaks
I had side loaded beta 1 but was able to join in members and download beta 2 this morning via software update. Will have to use today and see what may be updated different but glad I don't have to sideload any additional ones moving forward.
I didn't really have any issues with beta 1 so I am assuming they are close to official release.
Um, just checked the beta and it allowed me to sign up!
So far, pretty good. The updated widgets are very useful. Viewing an item in Samsung Calendar, you can select the hamburger menu and select Add a countdown widget. Great for things my older mind forgets...
Loving OneUI 7.0, not a big fan of the notification, but am actually starting to grow on it , doing the separated notification, animations are awesome just needs a bit more adjustments, with the Homescreen, But loving it , once it's Stable it will be a beast.
Im between separate notifications and then being all together, it just seems lot easier it being together not needing to remember left notifications and right swipe down toggles and this coming from a iPhone user
