- Nov 25, 2010
- 15,958
- 2,752
- 0
Is there any way to go back to my original setup after I do this?
Yes, you can flash this zip in ClockworkMod3. It will revert your filesystem to RFS as well as give you ClockworkMod2 with a prerooted, odexed system with some additional minor mods. You can alternatively use Odin to return to a completely stock ROM.
When did this pop up Ragnarokx? Those devs sure are cooking up some good stuff !
Question, it says odexed system. If that is the case you can't flash theme/add ons to this version you would have to flash to a deodexed rom to achieve this right?
Edit: I have noticed the old rule of odex vs deodexed doesn't seem to apply much anymore as I've seen some of the newer theme's over at XDA saying that they can be flashed on either version.
