Samsung Galaxy Fold 2 - Pre ordering?
Ok got my spigen slim armor pro case in bronze lol. It is like 2 different colors. Like the back and front case is light bronze and the henge protector and the sides of case is a darker bronze. I think it looks pretty good how they did it. Came in different packaging than my black one did and the black one didn't come with extra adhesive strips but my bronze did. But I think the case is good with or without the adhesive strips. Well the black one was and I took that off and put it on a couple times. Anyways here are some pics
Awesome I’m loving it ..it’s looking snazzy for sure ...
Good stuff thanks for sharing ...
BTW folks updating to Android 11 now just woke up to update ....unlocked US phone
Got it here last night. Broke a few Good Lock modules, but that was expected. Seems ok so far. The new animations look ok, but it doesn't seem as fluid as before. I am thinking of doing a factory reset. Are any of you planning on doing a factory reset? I used to do it after every OS update, but I have so many apps to reinstall and log in to it is a fairly long process. And while Samsung backup can reinstall apps there are quite a few that do not work for some reason, have to uninstall and reinstall anyway. If I do one it will be a "fresh" one only using Google to back up my contacts.
I'm not thinking of reset... My animations are turned off mainly... Waiting on updates for Goodlock for sure... Hopefully the small re draw I'm seeing clears up on my Smart Launcher
Good lock was suppose to be updated by now and of course it isn't. I'm able to move my clock back to the right side on my note 20 ultra after the OS update, but on the fold 2 I can only select left side or hide, and that's after the update of clock face in good lock. I was able to move to the right before the update. Don't understand how I can move the clock after OS update on the note 20 and not on the fold 2.
Hmmm interesting... My clock on inner screen stayed on the right
I can’t see that one being better than Spigen Slim Armor
I haven't been using a case. I put a skin in it and that's it. I've debated about the UAG. I personally don't think the fold 2 is case friendly, specially the front part. It seems to effect accessing the edge panels for me. I do like being able to using it without the case and how it feels, but I know it's risky to do so.
This last case is only one that my front edge works ...it’s thin but I like it and I have my skin underneath...I’m sticking with this one and when I want max protection the Slim Armor
emailists
