Samsung Galaxy Note 2 USB PC Connection problem
Hi guys and girls.
Hope this will help yougall.
I had this problem too and this is how I fix it.
1) get in to your note phone key pad press *#7284# (no this is not a joke)
When you press the last star (#) This will bring up an option that will ask you usb (modem or PDA)
2) change it to PDA.
3) at the bottem it says qualcomm usb. Click on it.
4) in side the click on MTP + ADB.
5) Then save and reset.
6) wait........:-\
7) wait.....:confused:.
8) when its back on. Thank god it did not blow up:)
9) plug micro to the note 2 and the the other end to your PC Or mac or what ever u have:eek:
10) let your computer down load and install drivers..
11) wait.......:confused:
12) wait.....:'(
13) wait some more...:mad:
14) when installing is all done. Unplug then replug phone.
15) there should be a USB symbol on your phone click on it. It should ask if you wsnd to use mtp or ptp.
Click MTP. Note some my have to click PTP for it to work.
16) check your computer for your open. On how to open your files.
17) Do dance of joy:D.
Note if this dont work please to not do #17 and stop reading.
Re: It's the cable!
1)Go to phone key pad press *#7284#
This will bring up options.
2)Click everything off modem. Then click on qualcomm usb
3)Click on MTP + ADB. Then save and reset.
4) thank god phone did not blow up
5) plug in to computer.
6) wait for drivers to install.
7) wait some more.
8) when all is installed. Plug and unplug phone
9) when you plug it in there should be a usb symbol, click on it then press MTP.
10) DO DANCE OF JOY.
PLEASE NOTE. if by any case it did not work. Skip # 10 and stop reading.
Re: It's the cable!
Nothing happens when I press *#7284#. I then hit dial and Verizon gives me a messages asking what the hell do I think I'm doing.
Re: It's the cable!
Well, that is Jack's first and only post on this forum. I'm guessing it's spam. I would never do anything that someone suggests in their first post on a forum.
Sent from my Galaxy Note II using Tapatalk 2
Hi there! I'm new (this is my first post, but hear me out), but I found a solution to this problem (kind of). What I did was I updated my Note 2's software, and then plugged it into the computer. After that, it was able to recognize it. Then, I followed this guide, which was possibly unnecessary, but I wanted to make sure that I would still be able to connect my phone in the future. See, the reason why the dialing method didn't work is because Verizon likes to be restrictive, so they prevented us from accessing the hidden menu.
I don't know how much I helped, but I really do hope that you get your phone working again. I was pretty frustrated until it suddenly worked for me... Good luck!
~Eggroll
When i connect my device, kies is stuck at the loading screen saying connecting. i've done the troubleshoot and restarted both device and computer. the phone doesnt seem to recognize the computer because I dont have the notification saying which type of connection i want to use (USB) however when i click battery it says charging (USB).. help?
I had the same issue on multiple computers. What I did to correct it was use the restart option on my phone while it was connect to usb and it installed the drivers it was having issues with properly.
don't know how the cable would do the trick. since the same cable has no problem pulling my bionic of my htc evo. but not the note2.
2 different computers and cables. although it now works on my laptop if i wait a few seconds. not all the time but it does work. and i have no idea what i did to get it to work.
the computer still has no joy though.
Re: It's the cable!
7) wait some more.
I just tried this work around and it worked. The problem I was having is that the drivers would install and when I tried to connect to Kies, it would say connecting and show the model phone and just sit there and try to connect. When I did this, the drivers that loaded actually showed the model of phone at the driver installation step. Kies then connected and everything works fine now.
Thanks man, I had the same issue, switched cables and plugged in with the screen unlocked and shazam. :cool:
Re: It's the cable!
When I press *#7284# nothing happens. When I hit dial all I get is a Verizon message saying the number cannot be dialed.
Hi guys and girls.
6) wait........:-\
12) wait.....:'(
worked for me, thanks
Ashok Dharshan
