Samsung Galaxy Note 4 Wireless charging on the way!
I just received mine today...In black. Works great, adds a little bulk, but really not bad..I'm talking minimal. The only problem I have is my two cases no longer fit. One is a Speck rubber case from verizon and the other is a Ghostek 2 piece case I purchased off of Amazon. The Speck case I cant even get to cover the phone at all. The Ghostek, I can get on, but I cant use the top piece as the phone is now just a little to thick and the top piece will not snap down as the rubber inside is pushed to far out. Just a heads up...If you purchase a back cover, you're going to have to go without a case for awhile.
I have the official back and while tight, I have a caseology case that fits and charges wirelessly okay.
Sorry I don't have a link cause it was given to me. But it's a caseology brand with a small diamond pattern on the back
20141126_081411[1].jpgSo it took a while but this morning I received my wireless charge mat. It came with a tempered glass screen protector, a bonus I guess because it took so long. Put in in place then put on and snapped the old Note 4 cover back on and had a slight, barely noticeable bulge on the back. Put on the charging pad and figured out where the sweet spot for charging was. Put back on the i-Blason cover and it fits fine. Put it on the pad and charges fine.
Woohoo!
View attachment 150768So it took a while but this morning I received my wireless charge mat. It came with a tempered glass screen protector, a bonus I guess because it took so long. Put in in place then put on and snapped the old Note 4 cover back on and had a slight, barely noticeable bulge on the back. Put on the charging pad and figured out where the sweet spot for charging was. Put back on the i-Blason cover and it fits fine. Put it on the pad and charges fine.
Woohoo!
You may not care but your NFC no longer will work.
Got mine today works perfectly but adds bulk to the phone over the standard back. About 1/8 inch more thickness.
I went overboard and got two regular Qi backs and two S VIew Qi backs. I am keeping the black one for me and sending the others so I can get the white S View when it comes out.
