Samsung Galaxy S III need help w/ APN settings for switching to Straight Talk
Re: Samsung Galaxy S3 need help w/ APN settings for switching to Straight Talk
I bought S3 from US..Verizon one...I unlocked it since I wanted to use it in India as GSM phone..Mobile is working fine except internet ....it works with wi-fi but not mobile internet...
When I tried APN setting, it does not show any option to add "New APN". This does not allow me to use mobile internet
Can you please help me out
Hi . I have a sgs3 . I am currently with at&t. I am wanting to switch to straight talk. Can someone
Tell me do I need a regular sim card or a micro sim card. And where do I find the apn to type eveything in?
Thank you in advance. I have a sim card that came wi th my phone do I still need to purchase another sim or a micro..
I just checked, I have a micro sim. I have at&t but wanting to swich to straight talk. Since I already have an at&t micro do I have to purchase a different micro or a sim to go to straight talk? Sorry about all the talk just checking everything so I wont have to write back. Thank you in advance again.
i have a samsung g3 with tmobile. at the time straight talk wasnt selling the tmobile sim card. so i had to buy a att card and gt it cut to a micro sim card. can SOMEONE PLEASE HELP ME with my apn settings. its been working great until the other day. :(
I just bought a sgs3 unlocked from fingerhut & have tried all the different APN's mentioned here and none have got me 3g or 4g. Anyone ever got an unlocked out the box sgs3 APN to work on Straight Talk? I have an at&t sgs2 I've been using on straight talk with no problems for a year now, tried the same settings under APN for s3 & doesn't work either! Anyone with any suggestions of what else I can try I'd appreciate it, I hate I can't use this phone's net or mms without wi-fi.
Thanks all!
After searching this site more I finally found APN settings that work & wanted to share in case anyone else runs into same prob I did! Heres the posting I found,
southside russell
Straight talk apn settings for at&t samsung galaxy s3
After renewing my monthly service my internet and mms stopped working with the apn settings i previously had. I sat arguing with ST reps for a couple hours and finally i was able to get new apn settings that have fixed the internet and mms issues. The apn setting are as shown below.
go to apn and create new apn. and enter
Apn:tfdata
skip down to Mmsc
Mmsc:http://mms-tf.net
Mms proxy:mms3.tracfone.com
Mms port:80
leave everything else alone hit menu and save. back out and go to home and may need to restart. should be working for you now.
as crazy as it sounds my husband and i both have straight talk att sims ive had mine for over a year and hes had his 3 months and we have different settings! which i just had to find and redo since our phones had a software update! my settings (older at&t settings) are as follows
Name- Straight Talk
APN- att.mvno
Proxy- proxy.mvno.tracfone.com
Port- 80
username-not set
Password-not set
Server-not set
MMSC- http://mmsc.cingular.com
MMS proxy- mms2.tracfone.com
MMS Port- 80
MCC-310
MNC-410
Authentication Type- not set
APN type- not set
APN prtocol
IPv4
APN roaming protocol- IPv4
APN enable/disable this should be lighter and already checked.you shouldn't be able to alter it
Bearer-unspecified
His settings(newer at&t settings) however are as follows
Name- Straight Talk
APN- tfdata
Proxy- not set
Port- 80
username-not set
Password-not set
Server-not set
MMSC- http://mms-tf.net
MMS proxy- mms3.tracfone.com
MMS Port- 80
MCC-310
MNC-410
Authentication Type- PAP or CHAP
APN type- not set
APN prtocol
IPv4
Bearer-unspecified
Then simply restart the phone!!!
I can't send or receive texts from short numbers I.E. promos. Normal ten digit numbers, all good, short numbers, nogo. Anyone else have this problem? Can it be fixed?
I also have problems with pictures, but, I just email them.
I just got my new ATT Note 3 to work with these settings. Now Everything is working MMS, Internet included.
The internet settings are from ST and the MMS settings I found on this site.
I hope this helps someone else ;)
Name
Straight Talk ATT
APN
tfdata
Proxy
not set
Port
80
MMSC
MMS Poxy
66.209.11.33
MMS Port
80
Authenication type
Pap or chap
APN type
default,supl,mms,hipri
Put these settings in my Galaxy Note 2 and my speeds DOUBLED! THANK YOU!
This is what I use on my Galaxy s3 Straight Talk At&t sim
Name
Straight Talk ATT
APN
att.mvno
Proxy
not set
Port
not set
username
not set
Password
not set
Server
not set
MMSC
MMS proxy
66.209.11.33
MMS Port
80
MCC
310
MNC
410
Authentication type
PAP or CHAP
APN type
APN prtocol
IPv4
IPv4
Bearer
unspecified
using these settings I am getting 5.5 dn and 1.25 up
*these settings. Lol
I just got this from Straight Talk today.
Here you go:
Name=Straight Talk
APN=tfdata
Port=80
MMSC=http://mms-tf.net
MMS proxy=mms3.tracfone.com
MMS port=80
Reboot
Go into messaging, General settings, Message center and enter the following:
+13123149810
To test send a text message, and send a mms (picture) to your cel fone.
My phone is now working 100%.
Also, my phone now says 4G lte with 2 bars
Roger
i did the same excepy there was an underscore between straight_talk
i still cant down mms pics can send fine
I have an att sgs3 with a straight talk sim and I've tried all these apn settings and none work for me . My husband had an att lg nitro on straight talk and thr tfdata apn worked for him now he has the s2 ffrom att ysung straight talk and he uses the same settings and they work all except his mms aby idea why ? My problen us my settings the only one I found that somewhat works us
Apn: wap.tracfone.com
Proxy: not set
Port: 80
Username: not set
Password: not set
Server: not set
Mmsc: http://mmsc.cingular.com
Mms proxy: mms2.tracfone.com
Mms port: 80
Auth type: not set
Apn type : default, supl, mms
My mms works slowly sends and downloads but works but my internet only works half the time not even half and its very veey slow when it does work. II've been trying to fix this for months with no success soneone pleaseplease help me . When my internet isn't working which is most of the time I have to restart my phone bt even then it only works for a little while . The 4g is upat the top of my phone HELP!!
I have been having same problem with my note 2 att phobe and hubby galaxy s3 att. How do we receive pic tex we can send but not receive
For my S3 which had been used with ATT previously, I simply set up a new APN with these settings .
Name=Straight Talk
APN=tfdata
Port=80
MMS port=80
Reboot
These settings worked great. I had used some of the solutions above, and saved them as another APN, without activating them.
mohitsl
