Samsung Galaxy S5 Wifi Problem
Ronaldo Rond
I am having wifi connection problem . My GS5 keep disconnecting from wifi every 3 - 5 minutes then it'll connected again .
Changed the wifi settings to static , turn off power saver wifi . Tried all that but nothing helps.
Tried factory reset . And it fixed the problem . But the problem appeared again in 4 - 5 days after i did the factory reset.
So i don't think its my radio problem .
And also other devices such as laptop , ipod , ipad works fine with my router so i dont think its my router problem.
Maybe software ? But idk . i'm not really good at something like this
Anyone else having this problem ? This is really frustrating .
I don't want to keep resetting my phone just for this because i'll lose all of my apps .
Please Help :)
Thanks
Sorry for bad english
Welcome to the Forums.
In Settings, Wifi, menu, Advanced Wifi, is the phone set to automatically disconnect if wifi signal is weak? If so, that may be the problem.
(And by the way, your English is good.)
Thanks for your response . I think its not the problem because it is also happened when i'm close to the router.
Did a factory reset yesterday because i really need the wifi :( .
But unfortunately , the factory reset is only for a temporary fix.
I resetted this phone 3 times . Just because of the wifi .
Nehasingh12
