Samsung Galaxy S6 Edge+ Cases
Grip on the case is OK but better than the phone without a case... its only 10 bucks on amazon so give it a shot and see what ya think. It matches the gold on the phone pretty good so that's a plus. The best part for me though is that it doesn't show finger prints as badly as the clear cases.
I dunno... looks kind of big and cheesy to me.... I like my ringke slim case much more
It looks great... such a thin case !! Do you really trust it to protect your screen if you were to drop your phone on the pavement ?
I got this inexpensive one from Spigen via Amazon:
http://www.amazon.com/Galaxy-Spigen...ag=hawk-future-20&ascsubtag=UUacUvbUpU4630651
I got the clear one so that it doesn't detract from the look of my Edge+. It covers the back and sides, but nothing on the front. It's minimal and doesn't really add much to the phone's thickness. If I dropped the phone and it hit the corners or back, I think it would be fine, but if I dropped it on the front screen, this wouldn't provide any protection. However, the lips above the corners might protect it a bit since it would prevent the screen from actually touching the surface if it was flat.
At any rate, I usually go naked on all of my phones. But with this one being so expensive and a bit harder to hold because of the edge, I thought a minimal case like this would be sufficient. However, I am a little interested in the clear s-view flip cover. I'd like to try it, but I'd like some feedback on it first. I had the regular s-view flip cover for my previous S6 (not the Edge, just the standard S6) and used it whenever I traveled.
Hopefully I never have to find out lol. It's got protection every where a case should have, maybe not as much as others but I think enough. I just can't stand to put a huge case on such a beautiful phone. It's only 10 bucks on amazon so give it a shot and see what ya think of it.
uploadfromtaptalk1440434223302.jpguploadfromtaptalk1440434240764.jpgSpigen Neo Hybrid Gunmetal
Sent from my SAMSUNG-SM-G928A using Tapatalk
Just got my Symmetry the case fits tight and about a 1/4 the size of the Defender but outside is a hard plastic so it's almost as slick as the phone being bare. So not sure I will be keeping it.
Haven't seen anyone talk about the tech 21 clear case. I like that it's protective yet very minimal. When you grip it from the sides you don't notice the case is there.Very slim case.
Where did you get that case? I could not find it on the Tech 21 website, showed nothing for the s6 edge plus. A link would be great! Thanks...
I got the Spigen ultra thin liquid clear case, thin as you can probably get and very form fitting while adding the needed grip so the phone doesn't slip out of your hand, clear as water and no bubbles on the back from being against the glass of the phone!
Galaxy S6 Edge Plus Case, Spigen® [Liquid Crystal] Ultra-Thin Premium Semi-transparent Lightweight / Exact Fit / NO Bulkiness Soft Case for Galaxy S6 Edge+ (2015) - Liquid Crystal (SGP11714) https://www.amazon.com/dp/B010MWE8X...ag=hawk-future-20&ascsubtag=UUacUvbUpU4639768
I just bought the spigen Neo Hybrid carbon on the edge case. It fits well, makes the phone easier to hold and I love the look.
Galaxy S6 Edge Plus Case, Spigen® [Liquid Crystal] Ultra-Thin Premium Semi-transparent Lightweight / Exact Fit / NO Bulkiness Soft Case for Galaxy S6 Edge+ (2015) - Liquid Crystal (SGP11714) https://www.amazon.com/dp/B010MWE8X...ag=hawk-future-20&ascsubtag=UUacUvbUpU4639974
Here's some pics of this case:
I love tech 21 cases. They always manage the slimmest designs that still do a good job protecting the phone
Sent from my SM-G928T using Tapatalk
T-mobile store.
T-mobile store.
Yes T-mobile store and yea it's not on tech 21's website which was really surprising when I saw it in store. Like that they started using the flex shock material to match the color of the case.
I was pleasantly surprised too. I love tech 21 cases. T-mobile seems to have a good relationship with them.
I found the tech 21 clear case at the Verizon store. I'm waiting on the Samsung S View, which I've preordered on Amazon, but I may end up switching between them, because I really like the tech 21 case.
This is the case I have as well, and as your picture shows so well, it's hard to tell where the Phone ends and the case begins.
LilPandaBear1105
