Samsung Galaxy S9+ unlocked won't connect?
Thats the problem , until you get a prepaid Verizon sim it won't delete those tmobile start up splash screen , like I mentioned that tmobile unlocked app doesn't mean anything because it orginally wasn't the phone , you can delete most of those tmobile apps, and should be able to delete the unlocked app from tmobile or once you put a verizon sim it will automatically reboot the device to configure.
I have a straighttalk Verizon sim installed is the thing. I've said this before. It's actually active and everything. Still is booting and acting like a tmobile device.
Look at this video , you think you can handle this?
https://youtu.be/eNkVFpVP0D4
Probably but wont be doing it. Going to send it back.
Remember how you said it can't be a T-mobile phone? Well, it definitely is. Got this notification this morning. Definitely going to send it back, it is locked to T-mobile and nothing is going to fix that no matter what I try. It's not going to work for me, it also lost the access point right after restarting it this morning before I went to the hospital. Anyway, appreciate the help but sadly, think it is a lost cause now. Unless the website I got the phone from can help me, there is little I can do to fix it.
I think thats best solution for you to send it back .
Its not a tmobile phone , its Sprint orginally.
Might be a sprint but unless a factory reset removes the T-Mobile lock that is currently placed on it, I can't do anything with it.
Factory reset won't change it from tmobile , either a sim not straight talk sim but a carrier sim or flash the firmware.
Thats why I mentioned if you have a friend or relative with Verizon sim you'll see it automatically reboot and configure to that carrier.
It should be with the Verizon sim card I have in it but I think most of mine are on AT&T or something else. So, just gonna see what they say and then send it back. Hopefully they either refund me or trade me for a Verizon only phone.
Yeah see what they say , if not ill help you flash it no worries on that end .
jacketempire
