psydefects
- Sep 23, 2013
- 1
- 0
- 0
Re: Samsung galaxy tab 2 7in wont charge or turn on.
Hello all, since many of you wanted to know how to open a tablet case, it's probably much easier than any device i have opened, just pry the back case open , starting from the corners, with a plastic tool, and work your way around. It may have a couple screws, mine has one at the sd card pcb. Now i have this weird thing too. Suddenly yesterday my battery was ultra low but on purpose because next launcher 3d has a bug and i can't reach the lock screen unless the bat is low and it starts to turn itself off, that moment appears for fragments of a sec the lock screen and timing with observation of the tap spots may work if i could plug it in timely. So at a moment screen turns black , and back cam led starts blinking. No button works,nor pluging it in does anything, it stays cold too. I have a 7.4V 23.46Watt 3170mAh double cell battery because it runs a quad tegra3 with 12x gou cores and the companion ulv core plusthe 10" screen it barely makes 3hrs continuously. My charger isn't a usb it's another type of plug ,flat elongated, with a ribbon lpc io cable hooked to the mobo. It's quite mofular buikt i remember 6x modules hookedbon a hannstar mobo (german) and i suspect its a clone of a tf 300 since it's made by pegatron abd sold unbranded. Can someone givevme charger specs do i dont burn it? I have multichargers with volt changing switch @ 1A, the charger has 1A input 1.5A output rating and 19V output too. Thanks.
